5 car audio noob questions! See if you can help
1. When wiring two amps to two batterys in the back, should each amp be wired to its own battery or wire them both to one?
2. Would a capacitor on enough batteries help reduce wear and tear on the alternator?
3. Do capacitors cause any resistance?
4. Would running 0 gauge from the alt to the batteries in the back directly be a bad idea? (2 runs one to back one to hood batt)
5. Are there any potential problems from running subwoofer wire out of the box through the port?
Thanks
Thanks
1. All the batteries should be wired together anyway, no difference either way.
2. Don't need a cap
3. Don't need a cap
4. Its a good idea. Fuse each run at both ends.
5. It looks ghetto as fuck. IMO
SMD Super Seller
My Feedback Thread
Thanks
1. wire them all to one battery.
2. fuck capacitors
3. FUCK capacitors
4. Go for it, make sure you fuse it..
5. not besides it looks like ass
2) no.
3) a very very minuscule amount. but dont bother installing one if its the crap kind that is essentially a pringles can encased in clear plastic with a voltage gauge on the top.
4) you can do alt to under hood battery, then from under hood battery, to the rear batteries.
5) no.
Thanks
1. Wouldn't matter, but I'd probably do it so there's peace in the universe...
2. no....the alternator still has to charge all the batteries as well as the capacitor
3. I imagine they do but you probably wouldn't see the difference
4. wouldn't be a bad idea
5. possible port noise....and like orion said, ghetto as fuck haha
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Put them together
Caps are bandaids upgrade Ur charging system ,HO altenator, batteries
Caps suck
Double fuse wires
No looks ghetto as hell
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
^^^^^Double fuse the wires huh?I'm curious why you'd suggest 2 fuses on the same run?
Because you would want to protect the wire by fusing close to each power source - the alt in the front and the battery in the rear.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 2279 Guests (See full list)
