is there a trick to this?
revoracing247
No need to do the wood filler first, just making extra work for yourself!
I do all body filler and it works fine. Do your best to press it into the hole first but the air holes happen to me too sometimes. If so just do another layer and sand it down too.
Team NorthWestSPL
I used only bondo for my box. Just have to make sure you apply enough bondo and really force it in there.
this thread is full of THATS WHAT SHE SAIDS.
TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET
150Db Club
160Db club in the future
I see krakin as a threat
yeah im just not that skilled yet with bondo and im afraid im gonna take too long trying to make sure all the holes are filled and it's gonna dry on me before i can put a good amount down. though i might just try going for it. just hope i don't have to apply second layers for like 60 of the screws :P
~ If it was easy, everybody would be doing it ~
wood glue and saw dust from cutting the wood. mix it up and fill the hole in with that then sand it. if needed add more then sand again.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Bondo wood filler. Push it in the holes and scrape the excess. It dries fast and sands easy too so you don't have to worry about it coming out when you sand it.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
alright i kind of just went at it with the bondo and i think i was able to get it ok. but we'll see how it turns out when i sand it down.
just wanted to say thanks for the help guys!
  • Who's Online   2 Members, 0 Anonymous, 985 Guests (See full list)
