What are you running on stock alternator?
Here is mine, finally.
Stock alt: 120A
Batteries: D925 front, D3100 in rear
Amps: AQ2200 and AQ100.4 (90.4)
Big 3 done, all 1/0 KNU OFC connections are soldered
1 run to the back, grounded in to the main frame/section of unibody from rear battery
I charge 14.4 hot at 50 degrees, and 13.5 at 80 degrees.
I have .7 of drop full tilt @2k rpm
I'll see 12.9 at idle when full tilt.
Stock alt. Not sure but i think 70 amps?
Big 3 1/0 ofc
D1200 upfront
1 Run of 1/0 ofc to back
Crescendo 2k @ 1 ohm Set by DD-1
Rockford p400-4
Charge 14.4-14.1
Drop on full tilt idle on heavy bass song could go in low 11's
On freeway 13ish no lower than 12.
  • 2 months later...
01 mitsubishi eclipse
stock alt 90 amps
batteries: i know this is bad running a wet cell and an agm but duralast gold under hood and xs power xp950 in the trunk
1 run of rockford ofc 4ga
big 3 in xs power cca 1/0 xp flex
running full car, head unit, and a kicker zx1000.1 on a fi q 15
lowest voltage drops is around 13.4 idling. about 14 when driving
once you get a speaker moving so hard that its possible to make tinsels slap, you are already kissing "SQ" goodbye. :D
Don't get me wrong, as I smoke Marlboro Reds, but if I saw one more kid with that smug-ass look (Look at me I'm smoking indoors) on their face, I was going to shove that thing so far up someone's ass that they'd look like a hillbilly trying to understand quantitative prediction theorem.
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
Currently on a stock 140 amp alt with a single XS Power d3400 I am running a Sundown saz3500d @ .5 ohms and a Sundown sax100.4 with each channel @ 2 ohms. The lights dim all to hell and I don't plan on upgrading the alt until my car is out of the manufacturer warranty. Then I will be throwing a Mechman 270 amp beast in it.
I haven't done the clamping on the current setup but if I had to guess I'm probably well over 4k watts on the stock alt. If I didn't have the d3400 I would be in some serious trouble.
Here is the format as in the other posts.
Amps: Saz3500d @ .5 ohms, sax100.4 @ 2 ohms per channel
Stock 140 amp Denzo alt
Battery: XS d3400
Wiring: 1 run of 0 gauge and 1 run grounded to the frame
Charging voltage: 14.8 volts
Listening voltage: 13s
Full tilt voltage: 12.6
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
  • 2 years later...
Currently running on my stock 90amp alternator:
Skar Rp-2000
2 group 35 AGM batteries (support up to 1000 watts as main 2000 watts as aux)
big 3 all 0 gauge
drop 2 12.8v after about 20min play time with headlights on and heat/ac
drop to 13.7 daytime no headlights.
going to be getting a 240 amp alt made soon hoping this one holds up untill then lol
2012 Kia Soul
 Infinity reference 6.5's  Coaxials
2x Soundqubed HDS312 @ 32hz (hdx312 waiting on alt)
1x Skar Audio RP-2000 (deaf bonce 4k on floor waiting on alt)
1 x Northstar group 35 front
1x Nortstar SMSAGM220 rear (have a second one waiting on alt)
0 gauge Sky High OFC
BIG 4
130A stock alt
Incriminator 10.1 (1200 watts)
Incriminator 3.4 (300 watts)
XS D3400R
OFC Big 3
Charging Voltage - 14.7V
Full Tilt - 12.7V
2010 Accord Sedan
XS D3400R
Clarion HU
Sundown mids and highs
Incriminator amps
Incriminator Lethal Injection 12"
  • Who's Online   0 Members, 0 Anonymous, 1816 Guests (See full list)
