dpeebs Posted April 26, 2013 Report Posted April 26, 2013 i ran my hifonics brz 1700.1 at 1 ohm along with my kicker zx350.4 stock alt putting out 95 amps ad i had the big 3 done and a napa battery 1 run of welder cable not sure on the awg but equivalent to 0 gauge. and 4 gauge knuconcepts. voltage dropped like a mother. then i got my H\O alt. lol
_94fleet Posted November 12, 2013 Report Posted November 12, 2013 94 cadillac fleetwood big 3 done xp3000 and d3400 stock 140a alt q1-3500 full tilt seen it dip to low 11s B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
bassaddiction Posted November 12, 2013 Report Posted November 12, 2013 110 amp alt big 3 i run of 1/0 stock + 1400 aq 2200 at 2 ohms and rf p 850.4 and small noname 4 channel drop to 12.8 at full tilt on idle 600 rmp drive around 13.5
cloud77 Posted November 12, 2013 Report Posted November 12, 2013 130A Stock Delco Alt MMATS M3000.1 on 12" ZCON MB quart 4.80 Duralast platinum up front Big 3 done with KNU OFC 1/0 1 run of KNU CCA 1/0 2 XS power d975s in rear KNU OFC 1/0 filling gaps I drop to lowest 13.1-13.2 from 14.4 on really punchy or low songs. Going to buy some welding cable for my run front to back. Anyone have experience with some 1/0 or 2/0 flexible stuff? 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
EKCASA Posted November 29, 2013 Report Posted November 29, 2013 105 Amp stock alternator Napa Premium Battery Single Run KnuKonceptz 0 KCA Cable to KNF-23 Block 4 gauge KCA to the amps BIG 3 with KnuKonceptz 0 KCA Cable Grounds ran same Amps: Two Rockford Fosgate Prime R250X1's @ 2ohm load rated 250rms at 2ohm One Rockford Fosgate Prime R250X1 @ 4ohm x 4ch rated 40rms x 4 @ 4ohm Runs at 14.1 - 14.4 at idle voltage drop to avg 13.5 http://www.stevemeadedesigns.com/board/topic/178713-ekcasa-1993-chevy-c1500-ext-cab/#entry2645541 www.facebook.com/EKCASA System: All Rockford Fosgate Front: 2 Pair Prime 6.5's and 1 pair Prime 5.25 Components Rear: 1 Pair Prime 6.5 3 Ways Subs: 4 Prime R2D2-12's Amps: Front: Prime R250X4 Subs: 2 Prime 500X1d's HU: JVC KD-AR959BS 2 Optima Yellow Tops Singer 230A H/O Alt. Lots of KnuKonceptz 1/0 and accessories 105 Sq ft Kno Knoise deadener
cnet15 Posted November 29, 2013 Report Posted November 29, 2013 105 amp alt big 3 rf 1000x1bd (really runs around 1300) two rf p400x2 for mids and highs one optima red top battery up front no headlight dim what so ever
vetkilr01 Posted November 29, 2013 Report Posted November 29, 2013 2011 Malibu 2.4l: 140 amp stock alternator Stock front batt, group 27 I believe...4 Marine deep cell batteries group 31's similiar to DEKA's (each weighs around 60lbs) Currently running a CT Sounds 7000.1 and a Soundstream Stealth stl 4.500 Big Three has been done Have 2 runs of 1/0 OFC wire to back. One run to each dual bank of Batteries. The battery Banks are connected to gether with mutiple runs of 1/0 OFC From the dual banks there are three runs of 1/0 OFC to the 7000.1 and a 4 gauge run of OFC to the SS amp. Car running resting voltage runs between 13.8 and 14.5 depending on what the hell the car wants to do Lowest voltage I have seen so far wide open is 12.5ish...Havent been that high again on amp yet, spider glue failed on one of my Wardens, this has been fixed, but breaking them in more before going all out again
MECHMAN Posted November 29, 2013 Report Posted November 29, 2013 You can run almost any amount of wattage on a stock alternator is the battery bank is big enough... Niel Barber, Tommy Mckinnie, etc... usually don't even run their vehicle when they are playing 40,000+ Watts RMS. The other thing to consider is what kind of vehicle it is. A Honda Civic might have a 65 amp alternator that charges at 13.8 volts, whereas a new Escalade will come stock with a 165 amp alternator that charges in the 14 volt range. Obviously the stock alternator on the Escalade will support over double the power that the Civic will in stock form, so you can't just lump all "stock alternators" into the same category. The primary difference is the amount of time you can play at high volume levels before voltage drop becomes a problem. Having a high output alternator mainly reduces the amount of battery capacity you have to have, and increases the amount of time you can play the system at high volume before voltage drop becomes a problem. If you don't want to change out the alternator, you can always add more batteries to the bank, and charge the batteries when the vehicle is not in use to help make life easier on the stock alternator. 1-888-MECHMAN www.Mechman.com [email protected]
Skullz Posted November 29, 2013 Report Posted November 29, 2013 95 Dodge Neon 2005 SRT-4 Stock 130a alt Stock battery and deka group 34 in back. Alpine mrp m500 Sundown sax 125.2 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
TheMonolith2001 Posted December 1, 2013 Report Posted December 1, 2013 2000 Jeep Cherokee (XJ) 4.0/4X4 Stock 117a alt externally regulated Sears Diehard Platinum battery Big 3 done with 0 gauge on top of factory wiring (except that stupid braided thing, I replaced that) 0 gauge run to amps/grounds PPI PC21400 (have also used Kicker ZR1000) + Pioneer PRS-D800 13v minimum on music when the regulator is being stupid and resting at 13.5, with test tones it was either 12.3 or 12.5 at idle. Keep in mind I am wired at 4ohm and nothing was turned on except the sound system and headlights.
