Kyblack76 Posted January 31, 2013 Report Posted January 31, 2013 A clip free deck is actually fairly common. Pretty strange man?!?!?. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
One Way Posted January 31, 2013 Author Report Posted January 31, 2013 Yeah when I get home ima take it apart and see if anything is loose. Then if everything seems good ima retune my whole system and go from there T-line build- http://www.stevemead...e-t-line-build/
Jessica Posted January 31, 2013 Report Posted January 31, 2013 If you set your deck at -5 it might be clipping. but then again, with the -3db overlap it might be fine. Still the instructions with the dd-1 say use the 0db for the headunit. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Kyblack76 Posted January 31, 2013 Report Posted January 31, 2013 ^^^^ Correct ...Yeah.... 0db on the HU... Did you use the 0db for the hu bro??? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
One Way Posted January 31, 2013 Author Report Posted January 31, 2013 I meant I used the -5 on my mids and highs amp and of course I used the 0 track for head unit T-line build- http://www.stevemead...e-t-line-build/
Nate Futuristic Posted January 31, 2013 Report Posted January 31, 2013 My Kenwood (forgot model number) doesn't show distortion 35/35 all flat.... down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
AI James Posted January 31, 2013 Report Posted January 31, 2013 why are you playing your comps or coaxes full range? do you have somethign else setting the low end of the crossover? most comp sets dont like playing all the way down freely. you may be clipping them out at a low frequency and the amp doesnt like it. remember your dd1 isnt showing if its clean at those low frequencies on your fronts its checking if its clean at 1khz. Why not set your gains at volume 32?
ChevyBoy95 Posted January 31, 2013 Report Posted January 31, 2013 i have had a few kenwoods, and all were good to 35 of 35 no clipping, tested with a dd-1 and o-scope. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
One Way Posted January 31, 2013 Author Report Posted January 31, 2013 why are you playing your comps or coaxes full range? do you have somethign else setting the low end of the crossover? most comp sets dont like playing all the way down freely. you may be clipping them out at a low frequency and the amp doesnt like it. remember your dd1 isnt showing if its clean at those low frequencies on your fronts its checking if its clean at 1khz. Why not set your gains at volume 32? I have them cut at 60 htz (recently changed it to 80)on my deck and setting them on full range I get a better sound out of it. Don't kno if that's correct but I've read somewhere that I can set the comp on full range you just gotta cut them off so it won't play the real low frequencies. As for the setting the amp at 32, I'm not trying to go around the situation and avoid it. I want to find out what it is. T-line build- http://www.stevemead...e-t-line-build/
Tarball Posted January 31, 2013 Report Posted January 31, 2013 CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
