CommonSyns Posted February 2, 2013 Report Posted February 2, 2013 I'm getting a Skar 4500.1D soon and I want to know if I'm good using this size fuse with my wire. I will be running the Skar 4500.1D at 1 ohm powering 2 ZVX subwoofers at 1 ohm. I've asked on the Skar board what size fuse to use to fuse the power wires going into the 4500 Kevin said to use 300A fuses, But I am going to be using CCA power wire from Audio Technix in the 1/0 size I will be doing 2-3 runs of 1/0 to the rear batteries. I saw that on the Audio Technix website that their CCA wire handles up to 250A fuses. But I am also upgrading my alternator to a Singer 250A alternator. Basically what I'm asking is that when I go to choose fuse sizes for my power wire and my fuse holders what size fuse should I use? 250A or 300A fuses, I don't want to burn up my CCA cable if I choose the 300A fuse. I also don't want to blow the 250A fuse due to the alternator out putting more than the wire can handle. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
Watch the bass Posted February 2, 2013 Report Posted February 2, 2013 http://www.stevemeadedesigns.com/board/topic/160990-what-do-i-need-and-questions/, fuse the wire for the current that the wire can carry, not more not less, it´s physik. "in the abundance of water, the fool is thirsty" Bob Marley
Ballen194 Posted February 2, 2013 Report Posted February 2, 2013 two 250s will do you man 98 Isuzu Rodeo Pioneer Deh-6300ub SUBS*Upcoming* SSA Xcon 18 4th order AMP Banda 3500 Mids/Highs Pioneer EQ Clarion EQS746 ETC. Two 1/0 run's KnuKoncepts 1/0 big 3 Shuriken BT-100 under the hood Shuriken BT-120 in the back
CaPRiCEx383 Posted February 2, 2013 Report Posted February 2, 2013 Fuse the front to rear runs at 250, Then you can fuse with two 300s for the amp if its short length, About 3-4ft. Aka from rear batts to amp. 90 Nissan 240sx Avic z-140bh Audison SR4 Audison Voce 6.5s CDT es-20 tweeters Sundown 1500v3 (2) DD 9510's 3 cube box 2 6" aeros XS Power D2400 & Xp950 Skyhigh/Knukonceptz/Rockford Fosgate wiring More Coming Soon.. Check my builds below. 97 Civic Hatch Build 86 Caprice Build you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Tarball Posted February 2, 2013 Report Posted February 2, 2013 make sure to fuse both ends of each run of 1/0 front to rear. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
michigancapri92 Posted February 2, 2013 Report Posted February 2, 2013 dont think you need to fuse both ends ... little over kill imo Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
CommonSyns Posted February 2, 2013 Author Report Posted February 2, 2013 http://www.stevemeadedesigns.com/board/topic/160990-what-do-i-need-and-questions/, fuse the wire for the current that the wire can carry, not more not less, it´s physik. So the 250A is good for the power wire with the 250A Alt? I just don't want to keep blowing fuses whenever I turn it up. two 250s will do you man Sounds good. Fuse the front to rear runs at 250, Then you can fuse with two 300s for the amp if its short length, About 3-4ft. Aka from rear batts to amp. Fuse both ends of the power wire from the front battery to the rear battery? make sure to fuse both ends of each run of 1/0 front to rear. If I don't do that what might happen? Also why? Just curious is all. dont think you need to fuse both ends ... little over kill imo What should I do? Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
