Antonio Moore Posted February 13, 2013 Author Report Posted February 13, 2013 So are you using 2 of your 4 channels on the 6x9? what are the other 2 channels running?There you go ... before I replaced product, optimize your install, then upgrade equipment if you have to ...T2 6.5 comps in the front How are they installed ?? proper deadning and as much airspace as possible ???Lol no deadening I just threw them in to replace factory speakers it's in an 04 Buick lesabre tweeters replaced alsoOptimise your install and then replace product if you have to.Ok will do
RooTxBeeR Posted February 13, 2013 Report Posted February 13, 2013 I learned quite a bit in this thread On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Kevin M Posted February 14, 2013 Report Posted February 14, 2013 I would run these... http://www.sonicelectronix.com/item_22203_Image-Dynamics-XS-69.html 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
DubNDodge Posted February 14, 2013 Report Posted February 14, 2013 So are you using 2 of your 4 channels on the 6x9? what are the other 2 channels running?T2 6.5 comps in the frontHow are they installed ?? proper deadning and as much airspace as possible ??? You mean 6.5s like a ton of air? I have always wondered this. So would it be idea to seal up all the gaps in the door panel with deadner (sealing the door up), or just use deadner on the panels themselves?(leaving all the gaps open) '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Antonio Moore Posted February 14, 2013 Author Report Posted February 14, 2013 I would run these... http://www.sonicelectronix.com/item_22203_Image-Dynamics-XS-69.html Aha no way not trying to get that loud those are almost $600 same cost of my amp and compsBesides they are out of stock...
bcbrassard Posted February 14, 2013 Report Posted February 14, 2013 See i know they were out there, 6x9 comps but damn thats a bit spendy, down to 60 hz the reviewer said they would play. thats pretty low, be nice to here them play. Yes, an informative thread
8ight Posted February 14, 2013 Report Posted February 14, 2013 So are you using 2 of your 4 channels on the 6x9? what are the other 2 channels running?T2 6.5 comps in the frontHow are they installed ?? proper deadning and as much airspace as possible ??? You mean 6.5s like a ton of air? I have always wondered this. So would it be idea to seal up all the gaps in the door panel with deadner (sealing the door up), or just use deadner on the panels themselves?(leaving all the gaps open) A good install makes use of the airspace in the door as the enclosure, deadening is the easiest and most common way to do it. I'm gonna hate
AI James Posted February 14, 2013 Report Posted February 14, 2013 Hertz Hi Energy 6x9 by far my favorite
DubNDodge Posted February 14, 2013 Report Posted February 14, 2013 So are you using 2 of your 4 channels on the 6x9? what are the other 2 channels running?T2 6.5 comps in the frontHow are they installed ?? proper deadning and as much airspace as possible ??? You mean 6.5s like a ton of air? I have always wondered this. So would it be idea to seal up all the gaps in the door panel with deadner (sealing the door up), or just use deadner on the panels themselves?(leaving all the gaps open) A good install makes use of the airspace in the door as the enclosure, deadening is the easiest and most common way to do it. So it is a good idea to seal those gaps up in someway? It seems to me that there would always be more holes somewhere '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
8ight Posted February 15, 2013 Report Posted February 15, 2013 So are you using 2 of your 4 channels on the 6x9? what are the other 2 channels running?T2 6.5 comps in the frontHow are they installed ?? proper deadning and as much airspace as possible ??? You mean 6.5s like a ton of air? I have always wondered this. So would it be idea to seal up all the gaps in the door panel with deadner (sealing the door up), or just use deadner on the panels themselves?(leaving all the gaps open) A good install makes use of the airspace in the door as the enclosure, deadening is the easiest and most common way to do it. So it is a good idea to seal those gaps up in someway? It seems to me that there would always be more holes somewhere There always will be, It helps to get as close to 100% coverage as possible. I'm gonna hate
