setting a bass amp. i was trying to use my dd-1 and when i touch the positive probe to the (+) output on my digital designs amp, it will spark when it makes contact and the amp goes into protect. i was using track 5 the "inbetween" setting. i tried it with the track playing and also with the track on pause and it sparked both times.
after messing with it i saw that the ground wire had come unsoldered off of the aligator clip, so i unhooked the dd-1 from the amp and unpluged the wire harness from the dd-1. i then crimped the ground wire back onto the aligator clip. i then plued the wire harness back into the dd-1 and as the plug "rca looking plug" made contact with the dd-1 it sparked??? with the ground re-conected i retried tuning my amp and now its not going into protect anymore, so thats good. so i figured everything was working okay but now the dd-1 wont pick up the 40 hz signal, i made sure that the track was playing and the radio was turned up. the dd-1 should be sensing the 40 hz signal because my amp has already been set with the dd-1 and i didn't move the gain at all. so, not sure if my amp fucked up the dd-1 or if the dd-1 fuck up itself.... help?
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
What was the gain set at when you first touched the probes to the + terminal?
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
the gain had already been set up with the DD-1 on track 5 a few months back. so the gain was already set properly i just wanted to go back and re check everyhting because it had been a while since i did it last.
2000 Dodge Durango
This thread mind fucks me. Waiting on Steve or tony to tune in
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I'm pretty sure all technical questions should be sent to them anyways. Let me see if I can remember the email.
found the problem.
http--,,--//IMG_0609.jpg
now im not positive but....
option 1: i didn't turn the gain all the way down from the privious setting before i touched the prob to the amp causing a spark when coming in contact with a conductor "the probe", and because of the high speaker output voltage going into the wire it melted / unsoldered.
option 2: the wires on the dd-1 were already unsoldered and touching each other so when i completed the curcit by touch the speaker terminal it shorted and the probe sparked not the terminal.
2000 Dodge Durango
first of all bro, i have NO IDEA how you can get a spark off the speaker terminal if A. there is no sound (was on pause). B. the Alligator clip was unsoldered (meaning it has no contact).
regardless, please send it to me
Steve Meade Designs
2160 Bell Ave Suite C
Sacramento, CA 95838
email tracking to [email protected]
if there is a problem with the harness, i will give you a brand new one. If its a problem with the unit, i will give you a brand new one and pay for shipping both ways. If its fine, i will ship it back to you at my cost...i just want to see what is going on. You would be amazed how many people have had "problems" with their DD-1 only to say "my bad, i did it wrong" a week later.
send it, we will take care of it one way or the other.
Follow my Tweet (Twitter)
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
