Dual 15 inch custom box help!!!!!
Well ive been designing a box for my 98 Honda Civic ex 2 Door coupe. Im hoping to start this weekend, I know how to build sealed but never tried ported could you look over this design and let me know if it would work without port noise or anything i may not know about.
I know its small for 2 15's but that about all the space i can work with about 4.3-4.9 cubes
Width can be from 34-36.
Height can only be 16 or i have to remove my 6x9's and i dont wan't to.
Depth can be from 16-22
These are the subs im going with-http://www.parts-express.com/pe/showdetl.cfm?partnumber=269-522
did some research these are acutal work good in small boxes and for the price if they blow not a huge loss or if i don't like sell them and get some Sundown E-15's or SSA DCON
cant bump in less than 12 hours, but try torres box calculator, the re box calculator isnt accurate, get around 12-16 port for a slot.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
K thanks for the info. The thing i dont get about torres what would be a good port width and diameter, what would be a good woofer displacement to use.
If you box can be 16.5h then that box would be of good size for 1 15" only. Then minimum net volume for 2 15" subs would be around 6 cubes.
I think that 2 12s would fit your application if you are below 5 cubes net.
I was going to go with 2 12's but couldn't find any cheap one's that looked good to me. I have 2 kicker cvr 15's in a sealed pre fab box that probably has 1.3 cub per chamber and its loud as hell. but one subs started to make a popping noise when i crack it up still fully functional its not blown,thinking it could be tinsel lead.
I bought the bravox because i went on their Brazil sites with google translator and it said they work well with small enclosers
A question i have is when i use re box calculator and i put port width at 3 and port length at 0 i get a total length of 20.5 but when i use torres if i put everything the way i did in re calculator 0 in length box i get 68 hz. But if i put 20.5 in port length its very close to the hz re calculator gives me.
Please don't take this the wrong way. I advise you take some time before you buy anything and read more around this site. Use the search feature, learn, ask questions Before you decide on a product.
Knowledge is power. And can save you wasted money in the long run.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
you should research this site, alot of useful knowledge to be obtained....I personally wouldn't go with Bravo subs, there are great subs out there for under $200 and you will be blown away by the performance they offer...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
  • Who's Online   2 Members, 0 Anonymous, 1102 Guests (See full list)
