back battery not getting charged? im stumpted!
I feel like a broken record lol. Check the resistance in your fuses to make sure one isn't blown. Sometimes they have a hairline break that will not necessarily show up when you look at them and testing the fuse by measuring continuity is a great way to ensure the fuse is either complete or broken.
it would be good to mention that you shouldnt measure the resistance of the fuses while they are installed.
check voltage on every connection first. if you find a dead spot, check the fuse and the actual connections at that terminal.
if you dont find a problem, check the resistance of your grounds.
what do they read on a meter seperately
If I remember correctly from yesterday front was 12.63 and back was 12.8 but the truck was on so that doesn't really count... Like I said I'll be back at it tomorrow and post up
typo?
Idfk let me test tomorrow! Work kicked my ass today my head isn't on straight haha
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
skittles:
Care to tell me why you can't test resistance on a fuse that has power? You can test resistance on a live circuit or dead circuit all day as long as you don't complete the circuit. If you wire the meter up in series to the circuit then you will not have problems but if you wire in parallel then you will fry that meter. I've tested my stuff like this the one time I blew a fuse and it looked fine to me and I found the problem instantly and it didnt give me any problems.
Found it! I tested before and after each fuse. Everything up front checked out at 14.5. Before and after the back fuse was 12.4 so I known its not a blown fuse just not getting charged. I get under the truck and meter the positive wire about 3 feet from the terminal and what do you know 14.5 volts I'm going to chop the wire and put a terminal on the end to extend it. Time for some audio technix ofc =]
Okay you checked the rear fuse but what about the front one? Im telling you something there is not completing that circuit and its either the ring terminal, fuse terminal, fuse.
I'm just one of those people that do not fuse the run from front to back to eliminate as many possible cuts in the wire and increased resistance, having done the fuse in front and rear once upon a time only to have the fuse holder melt from excessive heat generated from a loose connection i take all the precautions necessary to keep that run of wire safe. I guess it all comes down to each persons personal preference on what they consider as a safe way to do what is needed.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
