soldering or crimping
i know this my sound like a vs thread. but i was wondering which is better for a big three upgrade crimping or Soldering? i know they both have there drawbacks. which of these methods of putting your connections on is better? or would you be better off i you did both? crimp the connection the solder it afterwards.
Crimping is easier to get right if you have the right crimper, but if both methods are done right there won't be a difference in quality from my understanding. It is more difficult to get the soldering method right, but it just takes some practice and basic understanding of what your doing.
If you live near a battery shop they can probably handle it for you no problem. My shop does $2 per connection. Including the copper terminal, hydraulic crimping and dual layer heat shrink.
Then soldering would be your best bet its easy .. ^^^ he is right with the right crimp not much of a difference between soldering
If you have a decent hydraulic crimper you won't need the solder after.
The terminals and wire will be fused together in a solid connection.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
This^
You don't want to just stick the ring terminal in a vice and crimp it that way. You want to have a hydraulic crimper. Or any style crimper that basically makes the wire and the ring terminal one. (no gaps, one solid piece)
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
soldering is more secure but performance wise practically the same as crimping
This isn't exactly true, I remember reading a write up (I want to say skittlesisgood did it) that showed there was no difference in connection strength between soldering and crimping if done properly.
A good hydraulic crimper will almost fuse the terminal to the wire creating a VERY strong bond. I've heard of strength test showing the cable actually break before the crimp connection failing.
Good info. Got the link? I'd be interested in reading that..... And finding a good crimper
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
