P4killer_ Posted March 10, 2013 Report Posted March 10, 2013 Just thinking how i always wondered if there is a 1/0 quick disconnect solution.. and i never looked into it. Like taking an amp out and just unhook the cable either in line or preferably at the amp ie:. a compressed air line fitting, where you just clip it in or out when you change tools.. kinda thing. I just like to tinker and move things around and i hate the set screw because theres always a strand or two poking out and it always takes at least a few min to get it in there all nicely. and i hate 1/0 ring terminal fuse blocks because its a pita to undo the cover and then the bolt and bla bla. either option really only takes a few min max but just isnt like click and done.. i always thought thatd be nice to have. anyone have any idears? Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Skater229 Posted March 10, 2013 Report Posted March 10, 2013 Use LC40 Welding leads... I have used them in other high amp draws... http://www.usweldingsupply.com/lenco-05060-connector-lc-40hd.html When you install them put the male on the neg cable and the female on the pos so you won't connect backwards... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
justin0943 Posted March 10, 2013 Report Posted March 10, 2013 they do but they are rated at 175amp 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Skullz Posted March 10, 2013 Report Posted March 10, 2013 Not a cheap way to do it. http://www.ebay.com/sch/i.html?_odkw=1%2F0+quick+connection&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=1%2F0+Anderson+Style+Quick+Connect+&_sacat=0 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Skater229 Posted March 10, 2013 Report Posted March 10, 2013 Also the LC10 which is a little smaller... http://www.usweldingsupply.com/lenco-connector-lc-10.html Can also find red shells... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
P4killer_ Posted March 10, 2013 Author Report Posted March 10, 2013 Use LC40 Welding leads... I have used them in other high amp draws... http://www.usweldingsupply.com/lenco-05060-connector-lc-40hd.html When you install them put the male on the neg cable and the female on the pos so you won't connect backwards... look at that.. the set is like $16 and rated at 500a lmao NICE. double set screw too.. ill def try those out when it comes time. thanks Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
SnowDrifter Posted March 10, 2013 Report Posted March 10, 2013 http://www.remybattery.com/20-Gauge-350-Amp-Anderson-Industrial-Fusion-Kit-P9036.aspx ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
P4killer_ Posted March 10, 2013 Author Report Posted March 10, 2013 looks good imo Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
P4killer_ Posted March 10, 2013 Author Report Posted March 10, 2013 the andersons look safer though like unclip and the leads arent exsposed or anything.. sweet thanks guys Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
