Running 1/0 under carpet or under vehicle?
Im waiting to get my loom i live in a state with no snow so i dont need to be perfect
That looks good! 2 positive runs and a single negative run? I have seen that metal clip before in stores and have used the plastic ones before. Just follow the brake lines? That's what the wire is running next to correct?
Thank you sir
your welcome
So two or more should go under the vehicle? I'm planning on doing two runs of positive under the vehicle myself... with techflex and wire loom.
What model of tech flex? Depending on the cost You could also use pvc pipe.
The kind that fits 1/0... probably going to go with some welding wire because there is a local dealer here with great prices plus its ofc... but skyhigh wire is looking promising too... I think it was around 13 dollars for 50' but it will also be to clean up things and color code once the wire gets to the amps. How would I attach the pvc pipe to the frame?
PVC pipe hangers. I could only use one because of placement on the frame rail. But I used a fawk ton of Heavy Duty zip ties so they can hold over 40lbs in multiple locations
Do you have pictures? Also did you purchase this at a local hardware store? (ex. Lowes or Home Depot)
Pics of the PVC pipe?
Johns.jpgSuburban Coming Soon
looks good... def pvc and jacket on that wire
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Why would you tech flex and PVC? Why not just 1
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
i have 2 pos down driver side and 2 neg down the passenger side both ran thru the firewall and down the seal trim to the back
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
I always run under the vehicle no mater what . If something goes wrong I would much rather gave the wire up against a metal frame versus carpet lol
You guys have me thinking of running mine under the car for the simple fact it would be faster than trying to run under the carpet. In Louisiana we never get snow so thats not a problem.
Fi/DC/SHCA/SMD fanatic
Some people talk about changing the world, others of us actually do it.
Violet's Build:
Dynomat Xtreme deadener (all doors and trunk)
(2) RF 200w circuit breaker
RF RCA's
VM-1
1/0 gauge welding lead
Big 3
Singer Hairpin Alt (blue)
7" touch screen HU (factory)
Diamond tweets
Mids (front) RF 6.5
Mids (rear) CVL64MBX
Massive 7 band EQ/Xover/line driver
Sky High 12 g wire & heat shrink for 1/0 g
DB Link/Sky High Ring Terminals
2 - Fi BL 12's
Ported box tuned to 32
DC 175.4
DC 2k
D2700 and XP950 XS Batteries
Project DB connectors/step downs
DD-1
I have 8 runs under my carpet, no problems and you can't even tell
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
  • Who's Online   0 Members, 0 Anonymous, 2539 Guests (See full list)
