Vodka as surface prep?
Been reading around on safe handling of methanol in a closed environment and it turns out even a respirator doesn't do much... The stuff doesn't have a smell, so it's not exactly like I can tell if it's coming through my cartridges or not like I can with fiberglass resin.
Then you have isopropyl alcohol, which is metabolized into acetone. That doesn't sound too great either.
Which leaves ethanol, which is found in alcoholic drinks.
And since lab grade ethanol isn't sold out to the general public, I figured vodka, which is ethanol and water, would be my next best bet.
So... Has anyone used vodka as a surface prep to remove oils? Does it leave any sort of residue behind?
I'm really just looking for something that's safe - something that I can soak a cloth in and wipe away without worrying about poisoning(methanol) or burning my nose and lungs to all hell(isopropyl)
Oh... And the symptoms of methanol poisoning are very similar do a disorder called POTS that I have. So even if I was exposed, I wouldn't know it until damage had already been done. So that's another reason why I want to stay away from the stuff
Good question, only really one way to find out but with alcohol there is a risk of fire from the fumes reaching an ignition source, just make sure it is well ventilated.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Higher proof the better, though you're still adding water to whatever you're trying to degrease..
Hammerdown... 1%
should be fine as long as there isn't a ton of flavoring/additives which it shouldn't in the first place otherwise it shouldn't leave a residue
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
i got the limes
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
i got the limes
oh yeah i work in a warehouse that sells limes but i am not old enough to drink :'( come on Oct. 21, 2014
when has age ever stopped us? lol.
BMW M340 xDrive
Well, an easy way to check is to pour a bit out on some glass and wait until it evaporates
