CleanSierra Posted March 20, 2013 Report Posted March 20, 2013 To really answer this question, YES. You need a run of 1/0 to carry the current that both of your amps need. Make sure you choose a good grounding spot as well. Im not the one you want to try to troll. Just a fyi for you.
iROCKtheFOSgate Posted March 20, 2013 Author Report Posted March 20, 2013 Im running the same two amps in my truck. Im running good 1/0 gauge to a distribution block that accepts 1/0 in and has 2-4 gauge out. The runs off 4 gauge are about 18" and are Knu OFC so high stand count. I've got a fused distribution block with 150 to the sub amp and a 100 amp fuse to the T400-4. Under the hood on the 1/0 gauge I've got a 250 Amp fuse. yea but im talking ABOUT FOR MY XS POWER BATTERY IN THE BACK ... if i was gonna run everything off of one battery yea i would of ran a 1/0 awg to the back for the amps [sharedmedia=garage:vehicles:2273]
KMS Posted March 20, 2013 Report Posted March 20, 2013 id run 0 or 1/0 gauge just in case your going to upgrade in the future but 4 gauge is enough from the xs power to the amps yes so rune 0 gauge to the back then 4 gauge off battery to amps I thought 0 and 1/0 were the same. :\ Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT
MrSkippyJ Posted March 20, 2013 Report Posted March 20, 2013 id run 0 or 1/0 gauge just in case your going to upgrade in the future but 4 gauge is enough from the xs power to the amps yes so rune 0 gauge to the back then 4 gauge off battery to amps I thought 0 and 1/0 were the same. :\ They are. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
CleanSierra Posted March 20, 2013 Report Posted March 20, 2013 Basically the battery IS your distribution block. You'll be fine with 4 gauge from there Im not the one you want to try to troll. Just a fyi for you.
iROCKtheFOSgate Posted March 20, 2013 Author Report Posted March 20, 2013 id run 0 or 1/0 gauge just in case your going to upgrade in the future but 4 gauge is enough from the xs power to the amps yes so rune 0 gauge to the back then 4 gauge off battery to amps I thought 0 and 1/0 were the same. :\ haha yea they are the same [sharedmedia=garage:vehicles:2273]
iROCKtheFOSgate Posted March 20, 2013 Author Report Posted March 20, 2013 Basically the battery IS your distribution block. You'll be fine with 4 gauge from there i guess so.... but i know if i was just running 1 battery from the front i would have to run a 1/0 awg wire to the back for the amps .. and to me the battery in the back is more like my capacitor.... and i was just wondering if 4 awg was good enough to keep that capacitor(battery) charged up [sharedmedia=garage:vehicles:2273]
rockFord_Expedition Posted March 21, 2013 Report Posted March 21, 2013 Sierra nailed it in both his response and his own set up but don't take our word for it if you don't want to, prove it to yourself by doing the math yourself: what are the RF recommend fuse sizes for those amps? I believe 150A for the bdcp and 100A for the other. Those amps combined can draw 250A of current. True 4ga wire, with perfect termination is good for up to right about 150A as long as the run is not too long. So 4ga wire will work, but you will never see the potential of those amps. 1/0 wire is good for up to 300A under the same ideal conditions. So if you want to be one and done the right way for your wiring on this set up, go with 1/0 everywhere except for the wires going directly in to your amps where 4ga will be fine. An extra battery doesn't really justify smaller wire. And unless you need everything included in a kit, you can usually save $ by buying the wire separately. Do your big 3, the right way (check the pinned thread in this area) in 1/0 as well. After doing all of this, if your alternator is still stock, it is the weak link in your system. Upgrade it as soon as you can, I would go with a good brand, there are a few to choose from. I would go with something like a 320A depending on what draw you have besides your system. Just my $.02 Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
iROCKtheFOSgate Posted March 21, 2013 Author Report Posted March 21, 2013 i get alot of 4 awg is ok and go with some 1/0 awg im prob gonna try out the 4 awg first then try the 1/0 later .... i got my shipment in already of 2 rfk4 kits ... dont feel like going threw the retuning process because i ordered it online [sharedmedia=garage:vehicles:2273]
iROCKtheFOSgate Posted March 21, 2013 Author Report Posted March 21, 2013 so im gonna see how the 4 awg holds up and how the whole system works out [sharedmedia=garage:vehicles:2273]
