bass hits harder with my trunk open! WHY???
matt6288
Most likely its not sealed off. You could take an air compressor and have someone spray it around where its seals off and you get in the car and see if you feel air. Or possibly try a flash light the same way it night.
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Because race car!
Seriously I have no clue.
Because race car!
I love your posts Carbon
....because your sig is so cool hahah
97 Suburban
8 custom PSI Platform 3 18's
it is a sealed box
is your port firing into the cabin too or just the subs? if the port is facing the cabin, seal the box off from the trunk.. can you get photos?
they are not talking about the box. it means you have to seal the sound going to the back
the reason it does that is because it is cancelling out (when your trunk is shut). Bass is firing forward, then some of it is leaking backward through your leaky rear deck and the openings around the box itself. It travels backwards, hits the back of the car and then comes forward again but now its playing bass 180deg out of phase..basically reverse (to make it easier to explain). When you play a sound, and the same sound exactly the opposite, you get cancellation and the bass is reduced. Sorta like hooking up two subwoofers up out of phase, you know what i'm talking about? Anyway, When you open the trunk, the leaky bass is going backwards, and out of the car instead of bouncing back into the cabin.
This is why a car with a box aimed backwards typically sounds better then aimed forward (non properly anyway). Because the bass rolls off of the woofer and goes directly into the cabin, you get no cancellation. For a forward firing box to work properly, it needs to be sealed off from the trunk so no bass goes backwards at all, giving it no chance to cancel out.
Follow my Tweet (Twitter)
Even though it may look sealed from your pictures with that beauty panel for your amps behind your sub box... Physics say its not. It literally is impossible to have it sealed off from the trunk and the bass get louder when you open the trunk lid.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 1099 Guests (See full list)
