First Sub System. Need Help!
Hey there,
I'll be doing my first setup soon and I need some advice. I have some money to spend, but I'll look used and try to save where ever I can.
I have a Jeep Cherokee 95. I'll be doing it all in the back space with the rear seats down.
I really don't have an idea of where to start as far as brands are concerned. I know I want it to be very loud and have people be able to feel it from a good distance.
I've been reading that the more cone space the better, so I was thinking about going with multiple 10's or 12's? Is that a good bet?
Any help is appreciated!
Thank you!
If your on a budget bigger sizes can save you more money as the per unit price is where you spend most of it
But the trade off is box size to cone area + motor force
How much do you have to spend
Because you have a large car
You could easy do 4x oa18 on a t2500 for 1700
Or for the same price you could do 2 x series on same amp
I think do what i did i bought 2 Kicker CVX 15s make sure their CVXs not CvRs. THey are the loudest set of subs i ever bought and ive had a few setups and by far these subs in my opinion are the best
Mr ChevyBlazerMan
Setup
ALarm :) Prestige 2 way screen + Shock senser/Proximty Senser
Memphis Eq
2 Kicker Cvx 15 2 ohm
Custom Ported Box Made By Me :)
Amp Is Hifonics Brutus 1700D
Dash Speakers Not Sure on Model But They Are 3.5 Memphis
Door Speakers 2 Orion Xtr Pro Tweeters
Door Speakers 4 Orion Xtr Pro 6.5s
0 Gauge wire around in truck
Xs Power 3400d just got one from local shop on a discount. Just installed today with the big 3 upgrade O guage
Tomorrow hoping to run all door speaker and hook up my 4 channel Rockford amp
Get 1 SQ HDC3 18" on a q-2200. Or 2 HDC3 18s on a q-3500.1. That would be a killer setup. Set gains properly an run clean power of course. But make sure u have the electrical to support big power.
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
you could go with 2 sundown sa15's with a rockford 1200.1 that should give you some great bass for a lower cost. the sundowns are like 230 bucks each and the amp runs around 250 or so. and it will take less money on the electrical aspect. big 3 with a yellow top and a kinetik battery in back. everything should be less than 1500 together.
i have a friend who did this setup and he is waiting for his subs since these are pre sale to save more money you can get the audiopipe apsm 1500 for $125, if you get four 12" that is only $400 and if you 2 amps of the apsm 1500 you will rocking close to 3k and you ahve only spend around $600
good luck pm me if you have any question
amp apsm 2000 $189
C2 audio 12" $99 each free shipping
here's the c2 audio specs
presale on Sub 12" 600watt $99
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
  • Who's Online   0 Members, 0 Anonymous, 444 Guests (See full list)
