there is air in the system. Liquids such as brake fluid do not compress, however air does.
I'm gonna hate
All of them. Start with the brake furthest form the master cylinder.
Yup, do all 4. The brake lines are intersecting, so the right rear and the front left are on the same system, and the left rear and front right are on the same system.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Flush the whole system and bleed all 4 brakes.
make sure to top off the brake fluid before/after each of the brakes you bleed. if your reservoir runs dry while you're pumping the brakes, you have to redo the whole process because there will be air in the lines again.
You got it
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
