So at first, my brakes kept getting hard then soft and did this for a while, then it started going straight to the pads. And for a little I was able to ride on the pads, and now I can only for a brief 5 seconds. There's no leaks at all, is this a master cylinder problem?
its likely leaking between the master cylinder and the brake booster. What do you mean by "going straight to the pads" ? And are you SURE there are no leaks on any of the for wheels ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Possible that your brakes are so worn the brake fluid level has dropped to the point it sucked air and now need to be replaced and bled.
Possible the the master cylinder is going bad and losing pressure.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
With the car off, it still slowly goes to the floor? Might want to check the brake booster as well. Could be a leak in the diaphragm inside the booster, but like said above, check fluid level and bleed the brakes.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
there is air in the system. Liquids such as brake fluid do not compress, however air does.
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
