Hu or amp Crossovers ?
ImaNoob
Which do you guys prefer ? I guess im trying to figure out whats going to give me better results.. My older Pioneer Hu ( Model in sig) , or Rockford Amps.
I feel like i have sound quality issues( i know i dont have a true sound Quality setup), Like out of phase or something. Im using crossovers on both HU and amps and want to get rid of one or the other..
Any Input on the crossovers ?
Thanks !
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
which one will give you a better result? it depends on which one has a high DB slope. whenever I run into this I set the HU crossover as a cushion to what I set the crossover on the amp at. example if I set the LPF crossover on the amp to 80hz, I set the HU to 100hz.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
That is the way i have mine set now, i don't ever change the freq though, so i think i don't need that cushion..I run my subline at 63hz or 50 i forget
My HU HPF 0,-6,-12 LPF -6,-12,-18 My Amp HPF 24db Butterworth....Not sure on the sub amp though..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
I prefer my HU's Crossover. It's more convenient, I don't have to be going to and from my amp.
It tells me exactly what I'm setting it to, and it has a 24db/octave slope which makes it sound like the bass is up front.
Crossovers have nothing to do with phase issues ...
just saying
For the most part, I use my Headunit for my crossover settings ...
The amplifers that I run have no settings on them what so ever ... just a gain control knob. Simple ...
They amplify excatly what you put into them ...
Shouldn't have anything to do with the "Up front" feel of bass up with your stage and image ...
Most of that is aquired by time alignment (distance from your subs to your ears) ...
The slope controls how steep the roll off is on anything above your crossover setting ...
Just beacuse you have your LPF set to 70 htz doesnt mean it doesn't play anything higher than 70 htz ... The more slope you add to it, the more it cuts out above that desiginated frequiency ...
Just saying ...
always set the amp so in case the headunit resets youre protected
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I suppose this might also fall into my question area I posted a week or so ago ... ----> http://www.stevemeadedesigns.com/board/topic/166385-all-this-processing-power-where-to-start-hu-x-over-amps/
I would love to have a large discussion on this ...
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
