What i want to do is put another battery in my trunk. I currently have 4awg wiring from my stock battery to my amp. would it be safe to use the 4awg wire to the new battery, then use 0awg wiring to my amp, then use 0awg ground wiring for everything? would this be safer and
more efficient also?
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
no. if u put 0 gauge to ur amps and 4 gauge to the second battery u wont get enough power flow...
so i just use 4awg for everything?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
it would be better if u use 0 gauge for everything ! its better to save up some extra $$ and get it done right.. u might want to upgrade ur system in the future and u will have to do it anyways..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Use 1/0 on everything.. do big 3, 1/0 to second batt for power and ground, then 1/0 to amp....
Can also do multiple runs of 1/0 if needed..
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
okay so take out
okay so i should just completely get rid of the 4gauge and just use 0gauge for everything?
Kicker CS61234
Kicker 40CS674
Kicker KST25
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Is it safe? Probably, depending on exactly what is being ran. Is it best? Probably not.
Run 0 on everything if you can.
Yes,
The 4 gauge is only good for so many FEET of application.
Yes, the inputs on the amp are that gauge, BUT, you need to account for distance.
1/0 front to back, then step down, with fusing, close to the amp, with 4g.
Or do what im doing, and use nothing but 1/0 and then use a 1/0 to 4g reducer RIGHT at the amp. Tool maker, and or PROJECT DBr
okay so take out
if ur amps have the 0 gauge inputs yes.. if not, definitely use it for pos / neg runs from front to back and battery groundings.. and do the big 3 ( upgrade front battery groundings and alt wire) all in 0 gauge!
  • Who's Online   1 Member, 0 Anonymous, 1092 Guests (See full list)
