Battery cable wont reach D3400 in Blazer??
I just got my XS D3400 put in the blazer, I have the Ibar side post adaptors on it but the factory Positive wire is still 1" too short to reach when pulled tight. I tried to get some slack but had no luck. Any advice or ways around this?, I'm lost. Thanks
mine reached just fine when using the ibar kit.....guess you could extend the wires, then if you do that might as well just extend them and use the xs factory top posts on the batt
Team Flex Issues
Yeah, I got some toolmaker terminals to go on top so I wanted to keep the factory ones out of the way... Pisses me off after working all day to get it running... The negitive reaches just fine ironically.
what year?...probably doesn't matter though
it's not catching anywhere? I have slack to spare
it's a 2005 2 door same as 2004. I can see one goes to alt, one goes under the battery tray (fusable link?) and one goes down the wheel well beside the engine. It all trees together in some looming.
EDIT: already tried to loosen alt stud.
I had a similar problem with my car. The starter cable was too short, so I just replaced that with something longer. And the stock positive had this plastic form taped to it to give it a curved shape. Cut that out and the wire is now long enough.
Granted I have a Subaru instead of a Blazer... But you get the idea. Worst case is you can always use a fuse to get the extra length you need. It will add a few inches to the wire and a fuse is never a bad thing
Mine seemed too short at first also, after a slight bit of pulling and wiggling it reached.
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
  • Who's Online   0 Members, 0 Anonymous, 1540 Guests (See full list)
