XS Power
you should be fine, many of us on here including myself have done it with no problem.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
It's usually that as long as the batteries are the same chemistry type(AGM) and voltage type, you should be fine.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Yes that's fine. Just don't mix brands
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
What's wrong with mixing brands? (outta curiosity from your perspective)
Edited by Omega5002
2003 Kia Sorento
Team Subsonic Lows
You are good to go. Just be sure the batteries rest at a similar voltage. Like... Don't use an old decrepit d3400 that can barely start the car with a brand new d3100 or something. Just make sure both batts are in good condition ;)
Brands don't matter, battery type will be a more important factor to look at. Size of the battery matters little when wired correctly. If I have time I can post why later tonight and how current is drawn with multiple batteries
x2. Lol. I've never heard anything wrong with mixing brands AS LONG AS it's same type (AGM) and same voltage (Don't mix a 12V with a 14V). Think I've seen a few kinetiks and xs batts mixed together before... few xs and dekas...ect.
Sheena = pedobear
  • Who's Online   1 Member, 0 Anonymous, 572 Guests (See full list)
