What are some good budget subwoofer?
It appears as if you are not a hardcore competitor, so while I really like the sundown, and crescendo amplifiers, I think there are some better bargains out there that provide very comparable power at a much cheaper price.
Q1-2200D from aq/sq runs about $430 new
BRZ-2100 from Hifonics runs about $250 shipped
While those 2 (especially the Hifonics) may or may not not hold up to some of the more expensive options, both are known to put out rated power at rated voltage. My Hifonics came with bass remote, the ability to run slave/master, lowpass and subsonic filters, and everything else you would expect from any of the other 2kw amps. If you are running 2 subs rated at 300rms each, any of the options mentioned will be more than adequate.
However, if you know in advance that you plan on upgrading and getting more/higher wattage subs, I would highly recommend either the saz-3500 or the bc3500d. Either of those will run most anything you can fit in a trunk lol. Just make sure your electrical system is good to go.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
So budget is right around 400-500 from what you are saying?
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
  • Who's Online   0 Members, 0 Anonymous, 667 Guests (See full list)
