john253a Posted May 18, 2013 Report Posted May 18, 2013 Get the port area down Why are you making it bigger There is no need Drop it down to 6.5x 15.25 or 6.75x15.25 And make the port shorter Third subs can be in a box up to 10net I like around 8 for them But if you want max out put Keep the port around 14sq" per foot in the biggest box you can
vw passat Posted May 25, 2013 Report Posted May 25, 2013 if the port is 16sq'' or 17sq'' what is the difference between 14sq''? tx
RooTxBeeR Posted May 25, 2013 Report Posted May 25, 2013 if the port is 16sq'' or 17sq'' what is the difference between 14sq''? tx The more port you have, the more peakier the response will be, but a smaller range of output. Also vice versa with low port, wider range, but less peakier. what program is that? Torres Box Tuning Calculator On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
flood77 Posted May 25, 2013 Report Posted May 25, 2013 if the port is 16sq'' or 17sq'' what is the difference between 14sq''? tx The more port you have, the more peakier the response will be, but a smaller range of output. Also vice versa with low port, wider range, but less peakier. what program is that? Torres Box Tuning Calculator will it give you a cut sheet to print
RooTxBeeR Posted May 25, 2013 Report Posted May 25, 2013 if the port is 16sq'' or 17sq'' what is the difference between 14sq''? tx The more port you have, the more peakier the response will be, but a smaller range of output. Also vice versa with low port, wider range, but less peakier. what program is that? Torres Box Tuning Calculator will it give you a cut sheet to print dont believe so, It gives basic box, but not port On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
vw passat Posted May 26, 2013 Report Posted May 26, 2013 so wich one is the best more port or low port? tx
Smoove Posted May 26, 2013 Report Posted May 26, 2013 Your box is deep enough, you could also try 2 8" flare ports 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
john253a Posted May 26, 2013 Report Posted May 26, 2013 ^ dont confuse the bloke stick to lower port area around 14per sq and anything upto 10net is fine if my pc was working idd port a torres screen shot for you
vw passat Posted May 26, 2013 Report Posted May 26, 2013 OK but if it's possible can someone post a chart or something so when I'm building a box I have an idea what Im doing because I saw people make boxes like 2.30cft @ 17sqn or 4cft @ 16sqn. Tax for helping me
