XS Power
So I got my xs charger on Tuesday and decided to charge up my batteries.. Read the book 4 times to make sure I under stood everything and the I hooked it up.. Had a volt meter attached to keep a eye on things then I went back out side like 2 hrs later and it was a solid green light.. Indicating that it had been completely charged.. Well what throws me off is that the battery sits at 12.75 now... After a fresh charge is that a lil low or did everything go accordingly..
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Did you recondition or just charge? 12.75 is normal afaik but sometimes you can "train" a battery to sit a little higher. Usually around 13.1 ish.
Team B2
2008 scion xb bagged on 18's plastidipped matte black
4 18" b2 xc's pushed by 4 b2 m1s at .5 each
8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros.
157.7 sealed so far.
How do I go about doing that?
Discharge/charge a couple times
My d1400 would sit at 14.8 after a full charge. I drained/charged it 2 times and now it sits at 15.2
Snow, how exactly do you "drain" a battery?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Turn your car to "run" but don't turn it on
Flip on your lights/fogs/interior vents/defroster. Anything that drains power
Take the battery down to 10.5-11v range then immediately put it on the charger. They key is to not let the battery sit
Edited by SnowDrifter
How do I got about discharging the battery.... And yes I have the 1215
Question, would charging it on a 1.25A charger be enough? Or should I turn my car on and let it run for a bit?
You'll want a bigger charger
I wouldn't suggest turning on your car to charge the battery either
  • Who's Online   1 Member, 0 Anonymous, 1582 Guests (See full list)
