flood77 Posted May 26, 2013 Author Report Posted May 26, 2013 Scratch that their both like that pos to neg
zxsonnyxz Posted May 26, 2013 Report Posted May 26, 2013 But how does it play? Have you tried the battery check? STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
12volt_Trini Posted May 26, 2013 Report Posted May 26, 2013 the phase switch is used to eliminate speaker to speaker cancellation....i retract my previous statement being tht one has to be set to 180 and one to 0...you usually change it around until the bass sounds the best....sry for the misinformation.... Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
12volt_Trini Posted May 26, 2013 Report Posted May 26, 2013 Do like what most of these guys are saying....take a battery and bump the speaker once it moves forward and not inverted the polarity is correct Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
flood77 Posted May 26, 2013 Author Report Posted May 26, 2013 well heres what did i simply hooked it up pos to pos and neg to neg,and it slams,not sure on why they did this for sure but i know it sounds alot better and hits harder with no distortion
12volt_Trini Posted May 26, 2013 Report Posted May 26, 2013 well problem solved....guys at the shop messed up....luckily nothing was damaged Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
SnowDrifter Posted May 26, 2013 Report Posted May 26, 2013 Yup I knew it. Did it wrong and they are making up reasons Glad you got it sorted out ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
STEvil Posted May 27, 2013 Report Posted May 27, 2013 reverse wiring isnt wrong, it just doesnt help all the time and shouldnt be done unless you know what you're doing. In this case the shop at least did them all reverse, which kept anything from being damaged.. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
