XS Power
I had a thread like this awhile ago asking what I would need for 10k my question now is what I'll need for 2 5k's strapped at .5 ohm for a final load of 1ohm.
Will 6 d3100s and a d3400 up front be sufficient with a 220a alt?
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
Short answer is no.
You'll most likely be pulling around 1200 to 1300 amps at full tilt if not more running at that ohm load.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
What's a good way to figure out the appropriate amount of batteries?
I always see people asking but never knew what to look at to determine it
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Everyone seems to have their own formula of how to go about that task, and a large battery bank is a must with that much power and the amount of alternator comes down to what can you get fabricated to make it all fit.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
seems like everyone is failing to see how low is he trying to strap
Strapping at .5 will be .25 each amp...don't do it
I ran 2 5500's strapped at 1.3 so .65 each amp
DC 270xp with a 3100 under the Hood and 6 3100s in the back. It did OK, I could get it into the lower 12s after a song or two. Ideally with 10k+ you'd want 2 alts. Batts can only keep up so long
Team Flex Issues
im not going to contribute because one, i dont run at .25, and two, i havent ran close to 10k before. I think others should follow and not give out guesses if you havent done this before. This isnt really meant for those who have posted already.
  • Who's Online   0 Members, 0 Anonymous, 1004 Guests (See full list)
