OrionStang Posted June 4, 2013 Report Posted June 4, 2013 Haven't got it installed yet, but I am confused on the setup. There is an STD/NW switch that allows for a standard Fr/Rr/Sw setup, or network setup for a 3-way setup. I am using a 2-way front stage with subs in the rear, so STD would be the obvious choice, right? Here's the issue, I want to bandpass my mids, but i STD mode it there is only a HPF for the rear(my mids are on the rear rca's). So, should I switch to NW and treat my system as a 3-way setup? Technically it is. Im confused right now. SMD Super Seller My Feedback Thread
Swordlordboy1234 Posted June 4, 2013 Report Posted June 4, 2013 In for results. I'd vote 3 way being that the other option didn't work well. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
TaylorFade Posted June 4, 2013 Report Posted June 4, 2013 If you're 2-way + sub... then you're 3 way active and you want network. There's like... zero advantages of standard mode unless you just HAVE to have a fader. You'll alos lose your sub level out in network, but you can always use a knob for that. No worries.
LordArcane Posted June 4, 2013 Report Posted June 4, 2013 from what i played with on mine. sounds like you want the 3-way mode.
OrionStang Posted June 4, 2013 Author Report Posted June 4, 2013 Well, I definitely don't want my 6.5s playing everything up from 200hz, so I guess Ill go network. Like was stated, I lose the subwoofer controls, but I use an LC-1, so thats that. SMD Super Seller My Feedback Thread
audiolamb6 Posted June 4, 2013 Report Posted June 4, 2013 ken if ur useing the unit to run active then u need it to be in network mode and make sure u hit the reset . the menu is kind of hard to figure out but once u play with it u will no how to get where u need to be quick
Quiet Posted June 4, 2013 Report Posted June 4, 2013 Manual says you should have Low LPF, Mid HPF, Mid LPF, then High HPF. Go to NW1 to select the range (low, mid or high) that you want to tweak Go to NW2 to select the -3db filter frequency Go to NW3 to pick the filter rate (slope) Go to NW4 to choose Left or Right (apparently you can set each side independently, could help with imaging) http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-80PRS_OperationManual020712.pdf 2007 Pacifica Rebuild. Less quiet. Still not loud.
OrionStang Posted June 4, 2013 Author Report Posted June 4, 2013 Now that that's settled, how do I know what RCA should go to what amp? On the unit, the outputs are labeled R, F, SW from top to bottom. But in network mode, not sure which goes where LOL. SMD Super Seller My Feedback Thread
Quiet Posted June 4, 2013 Report Posted June 4, 2013 F=Mids R=Highs S=sub 2007 Pacifica Rebuild. Less quiet. Still not loud.
TaylorFade Posted June 4, 2013 Report Posted June 4, 2013 For some reason I can't fathom... Pioneer uses the rears for tweeters or the "high". Don't mix those up. You may pop a tweeter like someone I know that will remain anonymous So... Fronts - woofers/low rears - tweeters/high Sub - well... sub
