hazestorm23 Posted June 9, 2013 Report Posted June 9, 2013 First post did not find much on this amp as far as real RMS ratings as in true RMS not what the manual says. The amp is a ma audio hardkore hk-802sx high voltage amp. Says its supposed to be 4400rms if anybody has any info on this amp before I install it it would help
Amart88 Posted June 9, 2013 Report Posted June 9, 2013 First post did not find much on this amp as far as real RMS ratings as in true RMS not what the manual says. The amp is a ma audio hardkore hk-802sx high voltage amp. Says its supposed to be 4400rms if anybody has any info on this amp before I install it it would help Welcome to the forum. Check out this thread: http://www.stevemeadedesigns.com/board/topic/88869-ma-audio-hk-802sx-4400-watt/ My 2005 s10 blazer build. 4 zcon 18's walled.
hazestorm23 Posted June 9, 2013 Author Report Posted June 9, 2013 Thank you that helped glad I joined the forum. So I'll go another direction for an amp for system of the month
herbykw Posted June 9, 2013 Report Posted June 9, 2013 http://www.stevemeadedesigns.com/board/topic/88869-ma-audio-hk-802sx-4400-watt/[/url] I had one of these, ran at 14.4 volts. Swapped to an AQ2200. Had about the same output but sounded much cleaner on the AQ. Truthfully I would save a little more and get a different amp. 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
herbykw Posted June 9, 2013 Report Posted June 9, 2013 Sounds like you already have it. These are power hungry. Make sure you got the juice to keep it going 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
ChevyBoy95 Posted June 9, 2013 Report Posted June 9, 2013 does around 2k at 14v, 4k at 18v. [according to the thread linked] Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
hazestorm23 Posted June 9, 2013 Author Report Posted June 9, 2013 Yea I got it a while back only payed 150 for it. But I have backup amps I can use my mtx elite amps.
