2003 Kia Sorento Build log (Pair of Team AA 15's in and playing)
Well, big update, I finally got my Teams built
My friend Dave routed a regular Ti basket to fit the Team Motors
11043011_1074718179211767_26776775431707
10996067_1074717559211829_28736631599224
11053352_1074717562545162_78992504882446
11021156_1074717849211800_88478693254962
Team's vs an HDC3 lol
11001535_1073997009283884_73158761332568
10857322_1073997082617210_40950441897658
11025857_1073997049283880_16582734597966
After lots of grunting, cursing, more grunting, got the full loaded box in
10857322_1073997005950551_33562971007975
First impression
1. They sound fucking amazing and play very low
2. Voltage is a lot better when going from .5 to 1 ohm per amp(no it's not .7, even my dmm says .9, and that's just dcr)
Though of course they arent as loud as the hdc3's but that's because, 4 inch coil, heavy mass, stiff as hell, higher impedence, and they want more power, but oddly enough, it's harder to sit in the car, they have a much more solid sound and I feel like once I feed them rated power, shit is going to get scary. Of course, now to save up for more power, but I do love these subs, such perfect high powered daily subs. So AA ftw lol
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
AA blows.
ban this man...
I just reported this...
Yeah, it's cause I don't have AA with my AA's lol
2003 Kia Sorento
Team Subsonic Lows
Those things are massive!!! Im sure they make a ton of other subs look like midget subs.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Yeah, loading the box with them in it sucked, worth it though, love these subs
2003 Kia Sorento
Team Subsonic Lows
Who did you buy the motors from?
One have a "dirty" pole? Lmao that sounded...... Interesting
I got them from my friend Dennis Romasco, they used to be 18's with the original leads back when he had 4 of them in a 4th order on 4 AB 650.1's in a Rodeo
1402659_737155326298058_467506636_o.jpg?
Motors were from the 18's that blew(one with a ripped lead, and the other with a defective coil that shorted). Got them for a killer deal.
2003 Kia Sorento
Team Subsonic Lows
  • 3 months later...
Been a while since I posted here
Well, here's a few changes.
Ended up getting an Ampere 5k from Kevosinn for an awesome deal.
10365325_1109398375743747_27267215276206
Originally wanted to do 2 3800's at 1 ohm each but the 5k is doing excellent at .5
Also got 2 deka group 31's for dirt cheap, $200 for a pair from 2014, didnt want to run a 5k on 1 g31, dont care what nsb nutthuggers say, 5k is too much for 1 on daily, burp yes, long time music, no.
11196348_1116483385035246_55800583547966
Though ran into issues, my voltage was terrible, dropped way too quick, belt kept slipping(had to take my car to a mechanic to replace the timing belt again), and they put a shitty goodyear belt.
This was when I only had 1 jump of cca 1/0 between each batteries, and I was playing it one day from the way from work, smell amp burning(I was playing above tuning like a moron, like above 50hz)
Sent the amp to amp medics, wait 2 weeks, got it back
While waiting, I rebult my amp rack, because the way I had my batteries was very unsafe, moved around a lot
Did 3 jumps of 2/0 welding cable per battery, with the help of CNF terminals, and put grade 8 steel lockwashers to prevent loose connections
11667498_1154529317897319_74044261165020
Got my amp back in, put in my dual inputs, put 2 positives on the right battery receiving my positive runs, and the other 2 on the middle battery. Did the same for ground except on the right battery receving grounds.
11666317_1154525261231058_19190941712677
Re DD1-ed the amp, set the subsonic filter at 25hz, and lpf at 50hz(to prevent voltage drop from high bass)
Got much better voltage, like it takes a lot to push under 12 volts with dead batteries, and amp doesnt get hot anymore, sounds louder too
Also did a meter run, then a dats run to see where my tuning and impedence rise is
on the meter I did
147.4 at 34hz sealed on the dash
148 at 36hz dash door open
149.8 at 36hz outlaw(lost .4 from the last setup)
Scores are meh, was never suppose to be an SPL box, and I'll admit I'm not loud lol
Did a dats run on the setup
Came to discover I'm tuned to 28hz with the box in the car, fs of the woofers in the box is 22hz, and my impedence rise between 22hz to 45hz is between 1.1 to 4, 3.5 at peak, above 50hz is .8 reactive, which is dangerous, amp will play, but its really tough on the amp.
Explains why I play and peak so damn low, but I still retain a flat reponse, I do a 149 from 34hz to 42hz, a 148 at 30hz, and a 147 at 28hz(all outlaw scores)
If I want to gain, I'd have to shrink the box, tune higher, and relocate port, friend said try port up so it doesnt fire against anything to mess with tuning. I'll try it soon.
Though plan is to save up for another 5k to run each at 1 ohm to be cleaner and safer for daily. From my testing of 2 1500's at 1 ohm and 1 1500 at .5, I dropped a lot less on 2 and was a bit louder, and they stayed cold.
Also looking into maxwell capacitors as well, really dont want to put more batteries on the car, car hates 3 batteries already. May even build a bracket for a haipin alt on where my ac is since the ac compressor died.
2003 Kia Sorento
Team Subsonic Lows
  • 3 months later...
Been a while since I posted, but finally made a video of the setup, havent done much lately
2003 Kia Sorento
Team Subsonic Lows
