Single 12 or single 15
so do it. sell the two for enough to pick up a better one, you have to take into consideration that a bigger sub will want a bigger box. You have to experiment to figure out what you think is the right blend between space and bass.
CARS
14 Sierra crew cab daily, Small build coming one of these days
69 C-10 fleetside in many pieces, won't be done till the end of time
Last car '12 Focus with build log
http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
Well I just want to be able to fit a cooler for the beach or grocerys back there. My box for my two 12's at 3.8ft^3 and only leaves me 7 inches for trunk room. A box for a 15 would be 3ft^3 and leave me about 12-14 inches.
2002 chevy avalanche
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
Second set of T2652-s
D3100's
deadner
I think with how you've been describing you're needs you just need to sell the SA's and upgrade. I would personally wait till the X's and Zv4 come out instead of getting a Zv3. Not too long of a wait now.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
True. Those x-12's look pretty sweat
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
Do a single 12 at 1 ohms something that can handle 2k rms plus in a 3 cuft box.
would give you the same amount if space as the single 15 but in a big box for better efficiency.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Wire that bitch to 1 ohm, recone isn't too expensive for the sa's, lol. What kind of battery power and alternator power is that amp really seeing anyways? Amp will do rated on a solid 14.4 volts, but as steve showed us with his dyno if that amp isn't getting the juice it needs it won't do rated, and if you just set the gain down a bit and watch it I'm sure it will do fine
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Exactly what I was thinking^^^
Plus I have the same amp and the same sub but d4 model wired to 2 ohms, and I know I'm lucky if the sub is getting 1k watts without me clipping the piss out of it and revving the motor up, lol
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
I mostly listen to it when driving and downt drop below 13.2 at the amp on stock. But yes electrical up grade on the way.
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
If your upgrading elect
To support the 1500rms Constance
How much you looking to spend on a single 12 or 15 as you'll get a custom lvl6 12 for around 900
If that don't do it not much else will unless you want drop 4x that on a ddz12
  • Who's Online   0 Members, 0 Anonymous, 2293 Guests (See full list)
