Is The Problem My Brand NEW MechMan S Series Alt?!
Trying to find the big voltage drop, but I did not find it, ... running the car, & boomin', it drops like a leaf. I did not do the voltages with car running tonight, I did not have the help I needed at that point.
The topic was not meant to be inflammatory whatsoever.
But if the BATT is not getting recharged properly, then it could point to the alt, no?
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
- It will get load tested tomorrow.
Apologies all around.
Zeke
'14
Pioneer FH-P8000BT
13.1 resting with those numbers for dropping while the car off is normal, you're not really losing anything from front to back, so sounds like the alt has been charging your battery just fine. Come back tomorrow after you take measurements with car running at the spots I suggested earlier.
Then why the fuck are you asking about voltage issues with your alt when you're not even testing with the car running?
I do not need to have the car running to test for once source of voltage issues/problems ...
Are we going to trade barbs for the night?
Zeke
'14
Pioneer FH-P8000BT
the batts will not charge unless the alt is running, if your getting voltage drop, its becuase your using power and not replenishing it, thats what the alt is for , you will see less drop while the alt is running. everyone has drop when not charging. some moere than others depends on battery bank and consumption.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
hell even with an alt you can see voltage drop,especially when the demand is greater than the supply.....run the car then check your voltage and see the difference in voltage drop.
pioneer m650 pros
My inquiry was about the alternator not putting out its rated amount ... These D3400 run stereos, by themselves, a Hell of a lot bigger than this 900 watt'er.
Folks are right, recharging the batt is crucial, & if the alt is not doing that as efficiently as it is supposed to, then there is the problem.
I should have waited before posting, or at least re-thought my approach with what I had.
Zeke
'14
Pioneer FH-P8000BT
So you think your alt isn't efficient because its not charging your battery with the car off?
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Christ. No. When it is running. There should be no drops with what I am doing/equipment I have ... nothing this "semi-severe" ...
Zeke
'14
Pioneer FH-P8000BT
