Well, I currently have 4 sa-8's, all are d4.
Moneys not exactly all the best right now, so I am trying to find a solution without busting the wallet too hard. (3-350)
But right now I have a Hifonics BRZ1200 powering 2 of them at 1 ohm. The issue is going to be adding 2 more. Really didnt think it through very well, confused D2-s and D4s, figured on wiring (4) d4s to 1 ohm ( I know...)
So with that amp, would it be possible to pick up another one and just run a new set of rca's and remote to power the other 2 all in one enclosure? I know the amp's cant be linked together, but I should be able to use the RCA out to the other amp correct?
Sorry for being quite the newb at everything. Not something I do everyday. Prefer engines :)
The BRZ1200 has an output to feed a second amp so you can do that. You will need to gain match though.
cant you strap brz's? that would be the ideal setup for 4 d4's. 2 1200's strapped at 2 ohms (each amp seeing 1 ohm).
You need the MLX100 to link any of the BRZs except the 2400, that one can be linked without the MLX100, I looked into this for two HDC310s or a pair of Zv410s with two BRX2000s but they said the 2400 models are the only ones that don't need the MLX100 to strap/link em. I'm not sure where to even find the MLX100.
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
T-line on amp you have
That could be great, but a T-Line for (4) SA-8s would be pretty big right? I know you can make em small but for four of em?
Sub Amps: SAZ3k
That would work pretty well, I like lower tuning but I'm sure that'd still be a good ass box. I will have my Zv410 in a 1.5cuft @ 32 Hz with about 16sq per of port and 2000w. It's an L-Port but it's gonna be retarded loud. But that sounds like a good base to start off with for a T-Line design. I'd go with that as a starter then fine tune it to your wants.
Sub Amps: SAZ3k
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
