Sub up - port back design help
I'm planning on designing (through Torres) and building a sub up port back config. for a single Alpine Type R 15 in my Jeep Cherokee (SUV).
My first of a few questions...
Should I stack the port instead of having it bend in an L-shape? example:
Thanks in advance!
2000 Jeep Cherokee
15" Alpine Type R box build coming soon!
Good question dude, are you doing a single baffle or double? I know one benefit of a L-port is the added structural support, but not sure on the stacked port
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I was planning on a single baffle but with bracing dowels for support. I played around with numbers for a double baffle so it's not completely out of the question, but this will be a low power setup, only 300 watts :(
2000 Jeep Cherokee
Obviously woofer position will be important in my design too. Where am I best to place the woofer? Far from the port stack or right next to it? Would love to learn more on avoiding having the sub unload into the port
2000 Jeep Cherokee
What size and tuning on the box?
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Run it across the back in the L shape. Having a single 90" bend will me more efficient than several 180" bends
Never tried it any other way than L port, but have had awesome luck with L ports. If you round over the angle on the L and the outside of it, and make sure the port is the same width throughout the port you will help the efficiency and airflow of the box out.
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
Thanks everybody. Aiming for 3.5 cubes net tuned to 35 with nearly 14in2 of port per foot.
Will I have any loading issues placing the sub as far away as possible from the port on the top baffle? That is the only way my dimensions will work I believe. Like this crude sketch:
OR am I better off placing the sub in the middle of the box? or over/behind the port walls?
2000 Jeep Cherokee
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
