Currently for electrical I have big 3 with 1/0 awg a dc 270xp alt and 3 kinetic hc2400's as batteries. The site recommended tuning to 31hz so that's why its that low. My gain was set about 3/4ths of the way up or a little less. The sub does have all the cooling options. The amp shouldn't be clipping at all (bass boost all the way down) ill post some pics of the box later. I'm not with my car right now
'03 Cavalier LS Coup
DC Power 270xp alt
2 Sundown Neo Pro 8's
2 Selenium ST200 tweeters
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
1 CT Sounds AT7000.1D
Why shouldn't the amp be clipping? What method did you use to set gains?
sounds the subs wired wrong :shrug: thats where id start checking
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Gain 3/4 up? You are clipping that sub with a 2500 watt amp.
How can you say he is clipping? Simply knowing his gain setting doesn't tell anyone anything. It's all about HOW he got that setting
Exactly right! I surely can't guess what his pre-out voltage is, and therefore I can't guess WHERE his gain pot should go. OP, As Snow asked, did you set your gain with an O-scope or a DD1? Have you checked your grounding points for your batteries and amps? What kind of DC voltage are you seeing at the amp inputs?
2500 per sub ? That is way too much for a BL, for music.
2500 per sub should be fine especially with a box on the small side.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
I had a shop set my gains because they have an o scope. I haven't checked my amp inputs but I do know the batteries posts are all reading 14.2-14.4
DC Power 270xp alt
1 Sundown SAX-125.2
1 CT Sounds 125.2
2 Fi Bl 18's walled
Coils out of phase
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Have your ever played with a BL? Let alone any Fi/AA sub?
Their ratings are a joke lol
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1315 Guests (See full list)
