Zak Massey Posted July 5, 2013 Author Report Posted July 5, 2013 My amp positive should go to p1 and amp neg to n2 and n1 wired to p2 correct? Its a 1 ohm dvc sub. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
Zak Massey Posted July 5, 2013 Author Report Posted July 5, 2013 Here's the best pics of my box I can get. My car is super cramped with it in there haha '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
n8ball2013 Posted July 5, 2013 Report Posted July 5, 2013 A partitioned wall? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Zak Massey Posted July 5, 2013 Author Report Posted July 5, 2013 Just because I have two amps that won't be set at exactly the same power. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
john253a Posted July 5, 2013 Report Posted July 5, 2013 Do a polarity check on the subs Just because it says (+) doesn't always mean that, custom subs have been knows to have that happen before Recheck all the ground and pos and redo if needed Then get gains reset with o'sope
CleanSierra Posted July 5, 2013 Report Posted July 5, 2013 Build looks clean from what I can see on the computer. I'd definitely check to make sure everything is in phase and the subs aren't fighting each other. ALSO, the grounding possibility, plus gains properly set and THEN see where you are. Basically, everything John just said Im not the one you want to try to troll. Just a fyi for you.
Zak Massey Posted July 5, 2013 Author Report Posted July 5, 2013 Yeah ill definitely be checking polarity tomorrow just to make sure. As well as the grounds and all the wiring really. Its so bothersome that they are hardly moving I was really hoping for some monster bass with this set up. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
n8ball2013 Posted July 5, 2013 Report Posted July 5, 2013 So you said you have different amps. You mean gou have one kicker 2500 on one whats your other sub amp THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted July 5, 2013 Report Posted July 5, 2013 different amps? why? just use the same amps and knock that dumb partition out. instant louder.
DylanBunch Posted July 5, 2013 Report Posted July 5, 2013 how can polarity be a problem if 1 sub is in and each sub has its own chamber? unless I misread 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
