Zak Massey Posted July 8, 2013 Author Report Posted July 8, 2013 I had just used a 9v battery. I googled 'subwoofer pop test' and the vid I found the guy used a 9v so that's what I did. Polarity was all correct but only a little movement. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
SnowDrifter Posted July 8, 2013 Report Posted July 8, 2013 No, sorry they are in separate chambers 5 cubes per. The chamber is 21 deep x 18.5 wide x 19.5 tall the port is 21 deep x 18.5 wide x 2.5 tall. After displacement and all that jazz the chamber is 5.01 cubic feet and the port is tuned at 31.2 hz I just double checked the numbers. And what I'm getting seems to line up with your results/problem. The box is WAY too small I assumed what you were giving me was internal dimensions, so I had to add 1.5" to the external dims to compensate for the wood thickness ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
purplesyrup Posted July 8, 2013 Report Posted July 8, 2013 I was thinking the port looked very small too
Hellbilly429 Posted July 8, 2013 Report Posted July 8, 2013 Is the box flexing too? Kinda hard to tell with that shaky video but it almost looked like the front baffle was moving some Could be my eyes to, just curious 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
CleanSierra Posted July 8, 2013 Report Posted July 8, 2013 ^^^I mentioned the port area 3 days ago It doesn't sound like it has the output that 2 18" BLs on that kind of power should have. I can't believe that it would be ALL the recording devices fault. Those subs should get downright nasty. I never ran any numbers on his enclosure, but if he's in the 3 cube range, that is why they sound like a couple of 10s Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted July 8, 2013 Report Posted July 8, 2013 It sounds to me like the box needs to be destroyed and starting over with a good design needs to happen. Something isn't right, that's for sure. Im not the one you want to try to troll. Just a fyi for you.
purplesyrup Posted July 8, 2013 Report Posted July 8, 2013 Just bite the bullet dude. The box is way way too small.
CortezDTV Posted July 8, 2013 Report Posted July 8, 2013 Use a 12v to pop subs you need to see real movement to see if one coil is out of phase or not SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
fox_racin4 Posted July 8, 2013 Report Posted July 8, 2013 Use a 12v to pop subs you need to see real movement to see if one coil is out of phase or not Yep. I just use my batt. Bank to do it 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Zak Massey Posted July 8, 2013 Author Report Posted July 8, 2013 I've double checked the math and you are correct... The box is 4.375 cubic feet. Now i'm going back to the shop that made that box and ripping them a new a**hole. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
