please school me on alternators
oh ok. I didn't see a post stating he had a 2.2
But op, charging power>reserve power wins every time.
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
well their the answer its control by the computer you have to get the voltage adjuster so you can set it up to 14.8-15v or whatever you like it at.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
so much hate on battery banks.... .......
fisigggg.JPEG?raw=1 Crossfire_Car_Audio2_265_zpsd219cf51.PNG ablogo_zps4c550ed1.PNG?raw=1 download%204_zpsecsgajxi.JPG?raw=1 Audison-Logo_zps3f7b2a7f.JPG?raw=1 sundown_bg2_zps1d0951fc.JPG?raw=1 orionsmalllogosig_zpsf8d08612.PNG?raw=1 KaptionLogo_zps06c2a555.JPG?raw=1
I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY.
Wanna ride bikes?
Quote
On 9/16/2017 at 3:28 AM, Jake Pace said:
Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class.
But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics!
On 7/8/2013 at 4:01 AM, Banshee421 said:
Do horns get low
I see. I believe with mechman I don't have to plug that thing in. But it should help alot and get me louder since volts will be up.
It wasn't in the OP, ... it was in a different thread of mine that he offered that info. :)
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Battery bank can only do so much, since your vehicle is a daily driver, and not a competition vehicle with a million batteries plugged to the wall, your charging system needs to be up to par to have the reliability. Too much battery and not enough charging, and you'll end up having to put them on the charger often, and can't demo or play full tilt often cause the batteries will be drained, but at the same time, too much charging, and not enough battery, well all that charging is wasted cause the batteries can't store all the current.
You'd be better off btw adding a D3100 with the HC2400 then replacing the HC2400 with a D3100, but you should invest in a bigger alternator instead of a D3100.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Depends on how much he plays it while he drives. I mostly listen to rock and country at a mild listening volume. Barely any bass. Only when I really feel like cranking up some decaf is when they get used. Even then still, I can't drive around with my system at full tilt all the time... There has to be a point in where you take a break... That is when the alternator is able to help replenish the energy to the batteries. I had a sundown 2k on an 18 in a hyundai accent with a d2400 on a stock 65 amp alt... I just stayed within reason like I said above and I never had issues except with my other amp- AQ2200 blowing all the time...
Wanna ride bikes?
Quote
Do horns get low
You can add batteries all day long but unless you are making power to replace what is being pulled from the batteries than you're just draining the batteries. The larger alt will keep the batteries from draining so quickly.
You are correct but at the same time, If you are trying to pull 300 or more amps an alternator can only do so much ( and dont say well get a 370 amp alt....) You need a good electrical battery bank to store the extra power being made by the alternator.. When the bass hits and your alternator goes OH FUCK and gives all it can give... 300 amps.... That is all it gives!
Whereas four batteries can give 1000s of amps.
You don't see many big players running a lot of alts with not many batteries,
You also don't see many big players just running a massive battery bank.
Once you start getting into the 3k-5k range be prepared to upgrade to a better alt plus more batteries.
Every 2k I add I try and add another battery.
Wanna ride bikes?
Quote
Do horns get low
Should I upgrade my alt/get extra battery? I've got an AQ 2200 on just the stock 130amp alt and some autozone battery I think
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
I would get an extra battery. Also install a volt meter if you haven't already.
Wanna ride bikes?
Quote
Do horns get low
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
