Thanks bloodrise and bighossf150 for the feed back. If I use a AB 750.1 or 7.5k dc, how do I set the gain? Sorry for the dumb questions, this is my first big system.
To tune the amp for no distortion you use the smd-dd-1 or a oscilloscope.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Anyone used sundown audio ns-1?
Never used it but just looked at the specs. It only puts out 6k at 1ohm 13k at 2ohms linked so you will need 2 amps to do the 13k and need to make sure if you want to do it like that you get duel 2ohm subs so you can run a final load of 2ohms
141 on music.
this is scary....
this is scary....
What I mean by how to set the gain is, do I give the subs of 4000 watts total full power from a 750.1 AB amp as recommend by some of the guys on this forum or is there another way to set the gain to match them.
Thank you for the feed back.
I normally use a dd-1.
If it where me and being my first big system i would not over power that that much. i would just get a 5k and run both subs off the 1 amp at 1 ohm then once i get way more know how and what to listen for may be i would put the 7k on it but to begin with i would not do it.
141 on music.
  • Who's Online   0 Members, 0 Anonymous, 594 Guests (See full list)
