Why people not like strapping amps?
Karkov
Ohms law calc on my phone.
Just plugged random numbers in but here it goes
2500 watts @ 1 ohm = 50 amps
2500 watts @ 2 ohm = 35 amps
Less current means less heat.
Of course higher impedance would be more eff, but it ISNT HIGHER strapped 2ohm would be 1ohm.. its the same
He never said they will make more power, but be different in HOW they make power. Unless I am misunderstanding his post.
Will AD1 tell ouput voltage and current peaks? that would be badass and put an end to this thread for sure.
i don't have 2 of the same amps that are strappable other then my T4k's. And i don't have the power supply to bench 1 T4k, let alone 2. I would have to run some zero gauge over to my truck to do that and i MIGHT......but if i do, it will be for 1 amp, not 2. I am not planning on hooking up 4 runs of 1/0 directly to my alternators, that have NO room on any terminals anyway. I will prob try to squeeze ONE run on there and do some larger amps but 2 will be hard. I might be able to do 2 smaller amps (on my battery bank/bench), like T1000 bd's, but i don't have 2 of those....
so yes, that would be a great test! but the AD-1 is highly dependent on the power supply you give the amps and i am limited to how much power i can test on my battery bank. I need to just knuckle up and get 50 D1400 batteries and make a REAL bench. 3 just isn't enough.
Follow my Tweet (Twitter)
exactly my point!
Exactly what I had said from the beginning
2 amps strapped at .5. .25 each
2 amps gain matched at .25 each. Same thing
2 amps at strapped at 2 ohms. (1 ohm each )
2 amps gain matched at 1 ohm. Same thibg
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Good point, and there are not a ton of small power output amps that are strappable....maybe Skar can do a test with their amp...they're strappable iirc.
50 d1400s....weigh a ton literally lol...but that would be able to support some high powered stuff for sure.
I'm definitely in to see some strapped and unstrapped amps tested though. Thanks for the reply
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
I might be way off here, but this is what makes sense to me.
If strapping amps makes them more efficient, then they should make more power because they are not drawing as much current from your electrical which should in turn give you a higher voltage at the amp that should give you more power.
  • Who's Online   0 Members, 0 Anonymous, 1338 Guests (See full list)
