voltage drop remains after new alt
i have 2 batteries (group 31) and a 240A mechman alt. i just got my amps back today from repair and while driving (even on high way) the voltage drops. i got as low as 12.4 during most songs while at a high volume. lower volumes it performs much better than factory but im looking to stabilize my setup even at high volumes. i did some drive testing today and my RPM sits at 650 idle, 1100 on most road driving and 1600 at 55Mph. when i turn O/D off the voltage seems to stabilize a bit more but still not perfect.
upgrade to a larger alt?
add another battery?
add a second alt?
thoughts
nothing, gutted
Done big 3?
I'm assuming a diesel of some sort due to your RPMs? You may need to get a smaller alt pulley
Where are you measuring voltage?
A bigger alt. I had a 220 on my focus. It still voltage dropped. Upgraded it to a 300 and problem was gone.
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
I have the same issue as my xB is PCM controlled. I idle around 700rpm and I drop to low 12s, even while driving and playing full tilt. However my voltage maxes at 13.8 so technically a little over 1 volt drop.
Replaced or added to.like kyle said 2k is whwre most alts make power.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 737 Guests (See full list)
