How much different does Xmax make
Smoove
Lets say you have 2 subs with the same motors, same size sub. One sub has an Xmax of 7mm one way and the other sub has an Xmax of 14mm one way. And both subs are being pushed with the same power and same box.
What gains would be seen?
In your hypothetical and to keep things simple.... twice as much xmax + twice as much air = 3 db increase in sound pressure.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Don't get power or motors in the mix, same diameter double the excursion = double displacement.
What does Xmax (mm) measure?
I'm assuming something with excusrion
Edit: I mean precisely what does it measure? Excursion one direction?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I like this answer. I wont name brands, but I am doubling the Xmax on my shallow mount sub this weekend. same box, same power. Damn you Fedex, drive faster I gotta here and feel the difference.
Xmax is how far the cone/coil can be moved in one direction by applying current to the coil. Xmech is how far the cone/coil can be moved by pushing it with your hand or some means other than by applying current to the voice coil.
Xmech will always be more than xmax, which serves to keep the driver from being pushed to its mechanical limits (bottoming out, which is often confused with clipping) by the amplifier, when things are properly functioning and matched correctly.
Xmax is one way and there are a few methods for calculation, I like best the one that measures THD to be less than 10%.
Keep in mind this is theoretical.
There are a TON of other factors that you have to take into account.
-The compliance of both subs (to reach the larger xmax, the 2nd sub might have a stiffer suspension).
-Are you pushing your current sub all the way to its xmax? If not then you may not get the newer sub past that point either, especially with the same power.
-The sub with the higher xmax is probably engineered for a larger box. Hard to say what it will do in a smaller box?
Good question though :good:
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Occasionally you can hear the current sub reach it's max. Both subs have the same recommended sealed specs.The new sub will eventually see 2.5 times the power :) same power for a few weeks. Still curious to see if there is a difference.
  • Who's Online   0 Members, 0 Anonymous, 1224 Guests (See full list)
