need to know what AMP is needed for 2 12" audiobahns 400 watt rms each, duel 2 ohm voice voils. so i think thats a possible (0.5 ohm or 2.0 ohm) end load
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
  • 3 weeks later...
pricey? what about a crunch 600w max?
DEH-6400BT
QBOMB 4.5cu
You pay what you get for, AQ has clean power, 600w RMS or watts? If its watts then it's most likely 200-300RMS. When A amp says 600w MAX, it means that with EVERYTHING turned up it puts out 600w, which you will NOT want to. I'd go with the AQ all day err day son, patience grasshopper.
Go look at Steve's amp test Tuesday with the crunch 1000 or something like that. They do not do rated power and probly sound like ass. The soundqubed is probly the best you will get for cheap. Also what is your budget on a amp so we can help more
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Thought you were all up the PIPE's ass ?
buddys system. and having opti1233d's are up AP's ass yah?!
DEH-6400BT
QBOMB 4.5cu
I'd be wary putting 800 watts to those subs, but they don't really need a lot of power to move either. I think anywhere from 200-300 per woofer would be a great daily choice and all under $150 pretty much.
  • Who's Online   0 Members, 0 Anonymous, 579 Guests (See full list)
