maximum amount of on 4 channel amp
naughtyca
Hello
question
I have a 4 channel amp
80w per channel at 4 ohm
120w per channel at 2 ohm
pls dont ask what amp, its nto up to discussion, just trying to keep the topic on issue at hand
i have 2 tweeters at 75w @4ohm which will take up 2 channels
on the other 2 channels im thinking of using selenium t200 which are 8 ohm
can i use 2 t200 per channel wired to 4 ohm?
or can i do 4 t200 per channel wired to 2ohm?
As lkong as you present the amp with its recommended impedence it doesnt care what is on it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
since the st200 is 70w rms per speaker if I put 4 of these on 1 channel at 120w @2ohm, will this be louder than doing just 2 st200 at 80w @4ohm?
can't really say, theory in harmonics turns out way different than practice.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
It should be louder because you will be using more wattage.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 914 Guests (See full list)
