naughtyca Posted August 13, 2013 Report Share Posted August 13, 2013 Hello question I have a 4 channel amp 80w per channel at 4 ohm 120w per channel at 2 ohm pls dont ask what amp, its nto up to discussion, just trying to keep the topic on issue at hand i have 2 tweeters at 75w @4ohm which will take up 2 channels on the other 2 channels im thinking of using selenium t200 which are 8 ohm can i use 2 t200 per channel wired to 4 ohm? or can i do 4 t200 per channel wired to 2ohm? Link to comment Share on other sites More sharing options...
n8ball2013 Posted August 13, 2013 Report Share Posted August 13, 2013 As lkong as you present the amp with its recommended impedence it doesnt care what is on it. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 13, 2013 Report Share Posted August 13, 2013 ^^^^^ Yep..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
naughtyca Posted August 13, 2013 Author Report Share Posted August 13, 2013 since the st200 is 70w rms per speaker if I put 4 of these on 1 channel at 120w @2ohm, will this be louder than doing just 2 st200 at 80w @4ohm? Link to comment Share on other sites More sharing options...
RooTxBeeR Posted August 13, 2013 Report Share Posted August 13, 2013 since the st200 is 70w rms per speaker if I put 4 of these on 1 channel at 120w @2ohm, will this be louder than doing just 2 st200 at 80w @4ohm?can't really say, theory in harmonics turns out way different than practice. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Tarball Posted August 13, 2013 Report Share Posted August 13, 2013 It should be louder because you will be using more wattage. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
naughtyca Posted August 13, 2013 Author Report Share Posted August 13, 2013 It should be louder because you will be using more wattage. which one is louder, 4 st200 per channel @120w 2ohm or just 2 st200 per channel @80w 4ohm Link to comment Share on other sites More sharing options...
naughtyca Posted August 13, 2013 Author Report Share Posted August 13, 2013 can someone pls chime in Link to comment Share on other sites More sharing options...
naughtyca Posted August 14, 2013 Author Report Share Posted August 14, 2013 i still need answer pls Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 14, 2013 Report Share Posted August 14, 2013 dude.. your talkin minimal errrrrythang.. You hook it up this and that way, and tell us..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
