seperate amps left and right channels
deadbroke
In for info
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I tried that before , never did sound good even when the gains were matched so I went with one amp for fronts and one for back speakers. Is my way right? not at all I think its up to personal choice to decide
I run one for the left one for the right sounds fine it good even yeild better if you wanted them to sound equal as the passenger is further away IDK just a thought I run equal levels and will measure with a multimeter or oscilloscope soon
I ended up asking a guy at he local audio shop he told me it improves the signal because it eliminates cross talk in the amplifier. I was curious because it would make running wires easier if I did it like that
you should have no problem running a dedicated left amp and a dedicated right amp. I don't see why you would want to complicate matters, especially running fully active. What do you plan on doing? running a tweeter to the left and a mid to the right side of the left side amp (and vice versa)? Bass off the right amps left and mids/highs off the right amps right? LOL Don't do that bro, it is going to make your life a mess. If you are asking this question, you probably are not ready for the mess you are going to create for yourself. If you have 2 amps for your mids/highs, use one for your mids and the other for the tweets. If you have 2 amps TOTAL, use one for the woofers the other for the highs. If you have 3 amps use one for lows, one for mids/ one for highs. Don't make it more complicated then you need to. Running fully active is not for the rooky-est rooky as it is.
what? LOL - why do these shop workers even open up their mouths...it's like 90% of what people say their "local shop said" is bullshit.
Follow my Tweet (Twitter)
yeah im not really sure what he meant by crosstaIk never looked into it but I was more curious as to if it was something people did. i'm not really sure what I want to do with the system but i wanted to get the mounting locations setup and the wiring in place.
i have 2 sets of 6.5 components in my mega cab with one set in front doors and another set in the rear doors with focal crossovers powered by a t600-4.
i planned on having 2 sets of re xxx 6.5s ran by two t600-4 amps (one for left mids and highs and one for right mids and highs) and have my subs run off of a t4000 all processed with a 360.3. i have been told not to have tweeters in the rear doors but i wanted some kind of rear fill so i'm up in the air with that one. i'm open with suggestions i have a t4000 already and moved some seats around to put in a couple 18s but i want my mids and highs to keep up with the bass
any amplifier worth a damn should never experience crosstalk or whatever that dude was trying to say ... I would think the only way that could happen is power wiring or defective amplifier... so don't do that... like Steve said it will complicate things even if you think it makes it easier... one amp for mids and one amp for highs.... works like a charm...
also, if you're planning on running 4 component sets then good luck... I know I couldn't enjoy that but I bet it will be loud and clear... and you're just randomly using a Focal crossover?? have you made a thread on your supposed interior setup??? sounds cray
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
