it was fixed by turning the gain way down, but now ive lost a lot of clean output from the amp, what could be causing this issue? maybe the HU?
but wouldnt i be getting more ground noise then just from my 4 ch?
thanks
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
Could be lots of things, test and tune my friend. Like cj said rcas close to wire possibly grounding in the wrong spot. Alt whine is a bitch to find
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Start at the amp and work your way to the front.
With everything off pull the rca's from the amp, then turn it all back on and see if the noise is still there, if not then the problem is further up. If the problem is there with the rca's out of the amp then the problem is at the amp.(ground, ect.)
If you have no noise then put the rca's back in the amp with everything off. Then pull the rca's from the hu with everything off, then turn it all on and see if you have the noise. If no noise then the problem is at the hu. If you have the noise the problem is with the rca's.
Try this and report back
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
amen... Been dealing with it for awhile, still cant pin it down
I love my staffie :good:
So anti FACEBOOK it isn't even funny
ground headunit to the frame, add an extra ground if necessary, ground RCA's to the headunit itself like so 644225.jpg
make sure grounds at the amp are solid, still having issues? consider swapping out RCA's, at that point i'd look into it being an issue with the amp or an alternator issue, ohhh and I realized you're running a pioneer headunit, it could quite possibly be a blown pico fuse.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Pioneer head unit?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 735 Guests (See full list)
