Bus Bar Thickness?
It's not just about thickness.
How wide can you get it? Multiply your thickness by your width to get your cross sectional area. Get whatever has the most area. 1/4" x 2"or1.5" should more MORE than sufficient. Setting up your wiring equally so it's not all on one side of the bank will cut down the need for a really beefy buss bar since all it would be doing it making sure all your batteries are in sync with eachother vs. needing to conduct a bunch of current from one side of the bank to the other
I will add: If you are tapping/screwing into them, you'll want at least 1/4" thick IMO. Just so you have enough threads to bite.
The thickest they had was 1/4" thick x 1" wide x 8 ft long :(
I just planned to drill some 3/8" holes and use nuts and washers.
1/4 x 1" should be fine. Just spread your wiring around the bank
www.onlinemetalstore.com
That is where I buy all of my aluminum stock. I use a minimum of 1/2" thick material by at least 1.5" wide.
Make sure to use all stainless steel nuts and washers so you don't have to deal with rust problems.
Brass conducts better then stainless steel. I use brass and either copper or alum for buss bars.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
