lol. been keepin busy. things are goin well, just don't get on too forums too often since the break from spl started.
anyways to stay on topic, i think it's similar to the answer to the deadener/peel and seal topics we see too often. do it right the first time so you won't have to do it again down the road. long run, chances are it'll be safer and cheaper to run ofc the first around.
I disagree as damplifier actually dampens and absorbs the energy to dispense where P&S only mass loads. It's the big difference there between the two, one actually functions while the other doesn't. Where as both CCA and OFC will conduct
Not only do I use ofc, l look for the best like Stinger Skyhigh and so on. Not the cheap wire thats supposed to 0 gauge and is really 4 gauge.
Let's just say that you had access to two engines. One engine made 400hp and one made 500hp. The 500hp engine costs more money.
There would be no point at which one could say that the 400hp engine was superior to the 500hp engine, assuming horsepower was the only metric. However, one can rationalize why the 400hp engine is a better value but that still won't make it a 500hp engine.
How does that apply to this argument?
If I had to guess to how it applies here it would be this. If you have a 1000 watt amp that is fused at 150 amps and you use CCA which I believe is rated at 250 amps? Why would you need OFC which is rated for I believe 350 amps?
how it applies to your question. If you have a 400hp engine and a 500hp engine but you have a governor on both of them to limit the speed to 55mph. Then why buy the 500hp engine.
At Least that is my thought on it :)
You guys crack me up. Now, think about this for a second. You can't cheat the laws of physics - I mean, they are laws and not just some really good ideas. Value isn't accepted in physics, and for good reason. If you take the square root of 16, you'll always get four. There is no less expensive version of 16, just 16.
Debate is healthy.
  • Like (+1 Rep) 3
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Hey guess what
You also can't measure resistance with a DMM if there is voltage present at the point you are measuring resistance (ohms).
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
No one is arguing the number. True the square root will always be 4, as the capability of OFC to CCA will always be bigger. But...that is only comparing one to one. We all know and agree OFC is better, but that advantage can easily be counterbalanced by an extra run of CCA. Some times, running a single run if OFC will be cheaper, and sometimes cheaper when running two of CCA. So I believe as long as you are wiring correctly for the draw you will see similar results. And if the results are similar (I know two other instances of my own where they were the same alpine being one) then as a consumer you look at the next factor...price.
I agree, a civilized debate is healthy. Maybe some will change their mind and others will have a stronger understanding as why they believe as they do
  • Like (+1 Rep) 2
I really wanna see some real world results supporting what tony said about OFC but so far teamht 's switch is the best testing (and a legitimate test too) for the argument.
It's not like cca is the worst stuff ever either, I mean it obviously works pretty well if power lines use aluminum wire instead of OFC. That's some pretty major power transmission if you ask me so why don't they use OFC?
Edited by Pro7
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Team bassick alpine on the forum also switched and had no change in his score. Maybe he'll chime in with exactly what he was using for equipment
  • Who's Online   0 Members, 0 Anonymous, 2766 Guests (See full list)
